^ That's the idea!
Wire that switch so that it only has power when the vehicle is turned off. The VU4 manifold requires air pressure to keep its valves closed, so if someone were to press that button while driving and dump your tank's air pressure, your car will air out. Not super cool.
This can also be solved by putting a check valve inline on the inlet to the VU4, but since there's never any reason to dump the tank when the car is running, wiring the switch correctly is an easier, cheaper solution.
