Originally posted by Creation
View Post
2008 Slammed Jeep Patriot
Shouldn't. Get as much as you can off the fittings with a rag, and then wipe it down with solvent. Obviously you don't want your solvent rag to be so wet that any of the mineral spirits wick into the threads.
In reality, most of what pipe dope like Rectorseal is doing is lubricating the threads with teflon to let you get them tighter. Same thing that teflon tape does. Pipe dope has some sealing qualities (Rectorseal advertises "synthetic fibers", whatever the hell that means), but that's a bonus.
air out fgt
But seriously I cannot wait for the air setup to be finished. It will be soo cool. Also purists/ normal jeep owners will be mad.
Haha its going to be sooooooooo good. I should just buy Rockstars to tie into jeep purists and start attending their offroad events.Originally posted by SnazzyQ View Postair out fgt
Haha you'll be breaking necks left and right if you attend their offroad events.Originally posted by Creation View PostHaha its going to be sooooooooo good. I should just buy Rockstars to tie into jeep purists and start attending their offroad events.
explainOriginally posted by Creation View PostSo, I came across the striking discovery that my wheels "may" not fit with the bags on..
you wanna tuck, but too wide? or...Floccinaucinihilipilification
I'll try to explain.Originally posted by P78 View Postexplain
Currently my coilover sits about 3" away (roughly as I couldn't 100% see the tape measure from my angle) from the barrel of wheel and has a diameter of 62mm or 2.45 inches.
The bag has a diameter of 5.875" fully compressed and 5.5 when extended leaving me .125 of an inch of play when fully compressed if I'm thinking about all of this correctly. This applys for front and rear.
I'm already running 32mm spacers in the front, and 38mm in the rear. If I move the 38mm to the front, and pick up a 45 or so for the rear I should have enough play but i'm concerned that may be "too much" spacer. But, I don't have 2,000 for a lip and barrel rebuild of my wheels, nor do I have the funds to buy another set of wheels, and the trades i've been offered for my wheels have actually been worse speced than my current ones.
I'm looking for fender lip fitment as my end goal, I had planned on picking up another set of wheels in 4-5 months to do a full rebuild on (once I recover from the bag setup costs) I just don't have the extra money right now.Last edited by Creation; 02-11-2015, 07:45 AM.
I just looked closely over your components in the pic above. It looks like you've got a pressure switch, but I believe SwitchSpeed comes with its own digital pressure sensor. Unless you've got something interesting planned for that switch, you won't need it.
Also, since you're running a tank pressure gauge, you'll have to find a spot to thread in a sensor, or use something like a gauge tee (http://bagriders.com/modlab/products...GAUGE-TEE.html) inline on the feed to the VU4 or the line that runs to the tank.
Originally posted by Oh Damn, it's Sam View PostI just looked closely over your components in the pic above. It looks like you've got a pressure switch, but I believe SwitchSpeed comes with its own digital pressure sensor. Unless you've got something interesting planned for that switch, you won't need it.
I didn't buy the switchspeed package as I only need the manifold and the controller and wiring. My bag rider rep was trying to convince me to spend the $400 because I got a free line cutter and free line (although I already bought 60ft). My experience had greatly changed with br and I've started ordering elsewhere.
The pressure sensor I have will work correct since I didn't buy the switchspeed one? Or do I need to order it?Last edited by Creation; 02-12-2015, 01:09 PM.
