2008 Slammed Jeep Patriot
Originally posted by Oh Damn, it's Sam View PostHere's how I'd wire them:
Which fitting exactly is leaking? I had it in my head that you were using digital gauges with 1/8" NPT senders.
For the gauges I'm running the triple analog setup with the 1/8th senders. The PTC portion of them are leaking air on about 3 of the senders behind the gauge.
Also, my tank line to the middle t with the gauge wire is leaking on the PTC end. Any ideas how to prevent that from leaking?
They will need to be wired to accessory or ignition power eventually, or they'll run even with the car off.
I'm afraid 1/8" PTC is pretty notorious. The only thing you can really do is ensure that the ends of your lines are cut extremely straight and extremely cleanly, with no burrs or debris whatsoever.
Originally posted by Oh Damn, it's Sam View PostThey will need to be wired to accessory or ignition power eventually, or they'll run even with the car off.
Would tape around the wire help? Or do you think it won't slide in?
The 1/8th are the most difficult ones I've encountered.
You mean thread tape? Thread tape isn't really a sealant, it's a lubricant.
The issue here is that there are no 1/8" PTC lines that are DOT-rated. DOT-rated fittings like the SMC KV2 line have a much more robust sealing mechanism inside, so they're a lot less picky about perfect cuts and so forth. Add to that the tiny size of the 1/8" lines, and there you go. It's also possible - unlikely, but possible - that you have defective fittings.
Originally posted by Oh Damn, it's Sam View PostYou mean thread tape? Thread tape isn't really a sealant, it's a lubricant.
Alright. I figured maybe the extra material may help it seal up.
I don't think it's the fittings, I'll try some better cuts and see where it gets me.
My console still isn't done, so I need to find a way to temporarily mount these gauges.
Originally posted by Oh Damn, it's Sam View PostIt's not really the sides of the line that are sealed against, but the cut end itself. There's an o-ring in there that seals against the cut end of the line, and then some teeth that pull the line into the fitting. It's kinda screwy how they work, but they do work.
Any ideas of how to mount the gauges temporarily? We tried a box but it caved in due to weight. I thought about PVC but I didn't know how I'd stand them up and wood was an option but the garage drill isn't the greatest.
It should only be a few days. It seems the fabricator I thought was perfect for the job who had an open schedule due to a job cut, now has 0 time for my paid project.
Originally posted by Creation View PostIt should only be a few days. It seems the fabricator I thought was perfect for the job who had an open schedule due to a job cut, now has 0 time for my paid project.
You willing to teach yourself how to do fiberglass? It ain't hard.
Originally posted by Oh Damn, it's Sam View PostHm. Sounds like the last time I had a car in the body shop.
Every "creative professional" I've ever known has been terrible at time management. I don't tend to find my business relationship with them able to last much beyond a single transaction. Painters, fabricators, stereo installers, all of 'em. The only exception was the guy I had weld up by bag brackets.
You might have to go crack some heads.
And now you know why I try to do everything myself.
Originally posted by Oh Damn, it's Sam View PostEvery "creative professional" I've ever known has been terrible at time management. I don't tend to find my business relationship with them able to last much beyond a single transaction. Painters, fabricators, stereo installers, all of 'em. The only exception was the guy I had weld up by bag brackets.
I'm starting to see that. Everything I seem to send off takes 10x longer than my original quote. Hell, I'm still waiting on my adjustable toe links that were ordered 3 months ago with my camber arms with a 2 week turnaround. I got my camber arms but the toe links are still in progress.
WAOAH So its almost finished?
Cant wait for aired out pictures. Also all the jeep people will **** your car with the fire of a thousand sons. But thats ok cause pushing limits is cool. Congrats on bagging the car.
