Never ending quest of badassery
  • #91
    Wow.
    -Christian.
    • #92
      Yeah, I was amazed when I saw it.. Now lets hope I don't scratch it! Lol
      IG: @dubsesed
      "All is fair in love and low"
      Lowered Values
      PVW 5/15
      • #93
        Good work man...
        • #94
          Got the car back from Autoworks today. Looks killer. Ended up not doing much tonight except for routing the harness through the frame rail. Got another engine harness to chop up tonight too. Makes extending the harness WAYYYY easier.
          Now I do have a question. How is everybody making this section of the harness look pretty? Only thing I can think of is wrap it with some OEM tape and call it good.
          Donno what's next really. Maybe I'll reattach the brake lines, ABS module and booster within the next few days. I broke the clip that clips into the booster at the brake pedal so I need a new one of those. Anybody have a P/N on that?
          IG: @dubsesed
          Lowered Values
          PVW 5/15
          • #95
            Been lacking on the updates lately, so here's a few..
            Not much to report other than I ordered my turbo PTE 5858 journal bearing .63 A/R, T3 flange, 2.5" 4 bolt housing. Excited for that to get here! Motor will be getting cleaned and painted a wrinkle black next week sometime as I'm waiting for my buddy to finish extending my engine harness and wrapping it in tech flex. I ordered a couple rolls of OEM cloth tape today. **** **** balls is that stuff expensive!
            Got my IE manifold back from the powder coater and bolted it up to see how the VC and manifold look together, I wasn't dissapointed that's for sure. Loving it so far. Pictures don't do it justice. Bass boat status.
            I'll prob end up dropping the subframe next week and getting that powdercoated too. Because why not. Also decided to add up the total amount of money I have into this little MK4 not including the price what I paid for it in 2006.. $48,000. What. The. ****. I'm going to cry myself to sleep tonight.
            IG: @dubsesed
            Lowered Values
            PVW 5/15
            • #96
              Last few days have been kinda boring, all I've ended up doing was cleaning/stripping the block. I painted it last night with a wrinkle black. Ended up painting the head wrinkle black too. Actually turned out quite well, I'm pretty impressed with the VHT stuff. We'll see how it holds up..
              Pushed the motor into the engine bay just to see how the color combo is going to work out. It's gonna be awesome.
              Tomorrow my OEM harness tape will arrive, so I'll wrap the harness up a little bit, and then I'm going to drop my subframe to get that blasted/powdercoated the same gold that everything else is. I'll prob end up painting the steering rack while I'm in there too.
              IG: @dubsesed
              Lowered Values
              PVW 5/15
              • #97
                Well today I got the turbo in the mail. That was exciting.
                So I immediately went to the shop to bolt it up
                Already took the cold side off to get powdercoated. Should really bring everything together well. I'm still debating on whether or not I'll ceramic coat the manifold and hot side. I just have to locate a place locally that'll do it, and for how much.
                Then my buddy came up to help extend the engine harness a good 14" or so. We got that all taken care of, so all that needs to be done with that is taped, and tech-flexed. He said he'll have it done by Wednesday or maybe this weekend if he's feeling ambitious lol. Really, after that the motor can essentially go back in.
                IG: @dubsesed
                Lowered Values
                PVW 5/15
                • #98
                  Originally posted by mrkrinkle View Post
                  -Got sick of coils, ordered E-level.
                  -Put E-Level in, made sparks a few times.
                  -Replaced skid plate hardware elevndybillion times.
                  -Blew up about 10 inner CV joints
                  -Ordered Raxles
                  -Rebuilt transmission with a quaife and TDI 5th
                  Bags & Still scrape's? your too good! Lol and paint really did look too clean! saw reflection in one of the pictures perfectly, so please do share what clear coat was used . But really clean car man keep at it, cant wait to see final product of the tuck!
                  BENZWGN Build Thread
                  • #99
                    It was a really expensive clear lol. Apparently like $800 a gallon? I donno.
                    IG: @dubsesed
                    Lowered Values
                    PVW 5/15
                    • Really good work man. Paint looks top notch, all about the prep work to get it there. I am currently in the process of shaving my bay, I know how time consuming it is. Not to mention the wiring, which I refuse to deal with so props to you for that. Best MK4 build.
                      insta:yungwymo
                      • Thanks man!
                        Got some goodies in the mail today. IDF lower control arms which will finally get rid of the stupid positive camber MK4's get when aired out. Paired with the new front struts I got - Airlift performance series with camber plates on top + adjustable dampening + threaded shock body - it should be getting about -2* aired out. I should have the struts shortly after the first of the month.
                        Subframe me will be off to the powdercoater hopefully early next week if I can manage to modify it a little by then. I need to weld a nut on the inside of it for the skid plate bolt. My old subframe was so beat up where the skid plate mounts, that it would be nearly impossible to run one this year. Tentative goal is to have the motor in the second week of February.
                        IG: @dubsesed
                        Lowered Values
                        PVW 5/15
                        • Got a bunch of parts today. Got my new Airlift Performance struts in the mail today, which I'm actually kind of dissapointed with. I was hoping I wouldn't have to drill new holes in the strut towers to accommodate the new ones, but it looks like I'll need to I think airlift really dropped the ball on that one, can't wait for others to realize the same thing as most the people who bough them were upgrading from the slam series struts.. Other than that the build quality is phenomenal.
                          Got my subframe, cold side for the turbo, and motor mounts back from the powdercoater as well. Bolted everything up and ended the night with the motor in the car!
                          Hopefully a buddy is going to be selling me all of his old boost piping, so that would save a lot of time and energy. I'll know about that in the next week or so I hope, then the motor can come back out for final torque spec on everything, and finish up all the little details, then it's just a matter of pluming the fuel system, routing the battery into the cabin, and finalizing the tune. I hope to have it all running mid March.
                          IG: @dubsesed
                          Lowered Values
                          PVW 5/15
                          • Ordered essentially everything to plum my fuel system from the tank forward tonight (Bosch 044, 870cc Siemens). I'm a noob when it comes to -AN stuff, so I'm hoping I didn't just waste a lot of money on fittings. I'm concerned that I didn't order the proper fittings to adapt my Integrated Engineering fuel rail to the -6an lines.
                            This is everything I ordered:
                            Now will that all work with the fuel rail? Both ports are -8an O-ring. I also have Integrated Engineerings OEM Fuel Pressure adapter that is -6an O-ring for both ports that I'm planning on using.
                            Links to to said parts:
                            At IE, we are hell-bent on making the VW / Audi cars we love better. Our mission is to engineer hardware and software upgrades that out-perform original equipment in speed and strength. IE parts are second to none because we design them the way we want them for our own cars. We share your passion for making your...
                            Would be great to get a response quick so I can change my order before it ships.
                            IG: @dubsesed
                            Lowered Values
                            PVW 5/15
                            • I'm installing those same front struts on a friend's MKIV TDI later this week and he just received them this morning. They look awesome, the camber adjustment is key. I too wonder why they designed it so you have to drill new holes, my only guess is that there wasn't enough room to allow for the camber adjustability with the original stud orientation.
                              Sorry, I can't help out with the fittings, I know absolutely nothing about them haha. Looking good though man, love this build.
                              --Golden Boy E30 Build--
                              --Etsy Shop--
                              --@ayyyitsmikey--
                              • I also know nothing about those fittings, but I wanted to chime as a former MKIV owner. The car is and will be just gorgeous.
