Touring International
  • For the steering rack? I ordered all OEM parts and used realoem.com to get the part numbers for everything that I saw the need to replace=)
    95 318ti & 96 328is
    Compact Build Thread
    • Yes, the steering rack. Thanks for the info.
      • Master cylinder is all done
        I pulled the fuel lines and rear brake line that ran up to the engine bay on Friday. I have decided to refresh all gas lines while I am at it. More on that later in this update.
        Installed all of the new parts on the steering column Sunday:
        Yesterday I pulled the gas tank....yes I have officially lost my mind
        I will be cleaning the tank up, replacing all of the fuel lines, and cleaning up the underside of the car where the tank has been. I had a few fasteners snap under the car which has me quick frustrated. One of them was the stud for bolting the fuel filter to the car. I am trying to figure out how to remedy that situation currently. The other fasteners were the screws holding in the three mounts that ran the fuel and brake lines forward. Those will also be tricky to sort out.
        95 318ti & 96 328is
        • I saw your daily at the euro district, Those wheels are insane but damn do you pull them off.
          [CENTER][url=http://www.stanceworks.com/forums/showthread.php?t=66924][color=red]e28 build thread[/color] [/url]
          [img]http://i.imgur.com/hNTlNvf.jpg?2[/img]
          Instagram: [url=https://instagram.com/divingboardlord/][color=red]@divingboardlord[/color][/url][/CENTER]
          • I saw your car there too. It looked perfect! Thanks for the kind words
            95 318ti & 96 328is
            • Originally posted by Earl View Post
              Thanks a lot! It could use spacers and possibly taller tires but i'm pretty happy with how it's sitting now.
              • Still waiting on the rest of the column parts to arrive so I can put it back in.
                The gas tank is cleaned and ready to be put back together. I need to order all of the lines and gaskets yet. I also need to clean up under the car and undercoat that section.
                Before
                After
                95 318ti & 96 328is
                • Been working on little things the past two days.
                  I "rebuilt" the throttle pedal assembly. Everything is brand new besides the lever itself. My old pedal return spring was snapped and not doing anything. I don't recall the pedal ever feeling bad so I was surprised to see that.
                  Old
                  New
                  I also got pads for the brake and clutch pedals
                  The steering column is also back in the car now. I placed an order for the fuel lines above the tank and need to start wire wheeling and undercoating the tank area under the car.
                  95 318ti & 96 328is
                  • Finished buttoning the column up yesterday
                    95 318ti & 96 328is
                    • I have been really busy planning a GTG and what not lately but figured I would post some pictures of a few things to keep things lively in here
                      If you can't buy it, make it (new one is stainless)
                      I cleaned and painted the rear bumper carrier as well as the mounting brackets (and installed OEM hardware)
                      95 318ti & 96 328is
                      • Finally scored a missing piece of the puzzle:
                        Racing Dynamics Non M lip
                        Unfortunately I wasn unaware that the lip is slightly different between the two non M bumper styles so I will have to make some reliefs in the top of the lip to fit around parts of the bumper vents. The good thing is that the lip isn't perfect and needs some fixing anyways.
                        You can see the small semi-circle reliefs now that are for fitting around the vertical slats in the wide slat style non m bumper. Those will be filled in as well.
                        95 318ti & 96 328is
                        • Maybe get a facelift style front bumper while you're at it. Looks way better than the old version anyway, plus you don't have to customize it to fit.
                          • The car had a "wide slat" bumper originally that I still have but I much prefer the above bumper. I also have the "wide slat" style bumper on my daily coupe.
                            95 318ti & 96 328is
                            • Did you by chance score that lip off of someone in Vancouver BC? I finally found one for sale there and was too late, it had sold by the time I found it. Great build too!
                              @projects_always
                              • Haha that's the one
                                95 318ti & 96 328is
