#cleanalltheparts
Touring International
Thank you=) Means a lot from you
What do you mean by "depower" the rack? The plate is essentially a fancy way of looping the rack.
Originally posted by cheaptalon View PostAre you going to de-power the rack as well, or just sticking with the delete plate?
E36 318iS Clubsport : Build thread coming soon
Definitely wont be doing that since it will void the lifetime warranty on the rack.
Media blasted the shifter carrier
It was a pain trying to get the rouge out of the inset spots so I decided to clean it up the easiest way I could=)
My orders from Garagistic and Ireland Engineering also arrived
I am currently ordering all of my clutch components and have a dssr on the way as well=)
DSSR arrived and is the perfect length. Glad that the e30 m3 lever ended up being the only one that was even close
Currently modifying my z3 lever to fit. BMW revised the bushing at the bottom of the lever to eliminate the need for the yellow washers. Unfortunately that makes it too wide to fit in the DSSR.
