Peyton. e28 pt.2
I was thinking that some time ago. maybe someday soon.Originally posted by Wyatt Lay View PostSo good, spot on, just needs euro lights at this point.
Originally posted by Queef|Chief View Postlove it man! makes me need a older bmw in my lifeThanks dudes <3Originally posted by Bronzit View PostIt makes me happy.
Took some photos at my "spot". Happy with how some came out for a phone.
Also got some pics of Alex's cosworth on the new wheels.
Finally got a part Ive wanted for some time now as well. e12 mirror plate. Bought an e24 one thinking it would work and that screwed me. Glad I found this one.
Originally posted by fancy sauce View Postvery nice.Thank you guys.Originally posted by Luke Girard View PostUr car is SEX
More maintenance. Car has leaked powersteering fluid the whole time I had it. Thought it was the washer on the high pressure fitting end that goes into the pump. Ended up being the feed hose from the resevoir the whole time... So a year of powersteering fluid being thrown under my car for two old hose clamps. Damn. Oh well its fixed. Cleaned the shit out of it from what I could get to with the pump in and threw a half inch smaller bent on it so it wasnt sitting at the farthest position on the adjuster.
since I was on a fixing spree, I figured Id try to fix my exhaust leak. It was leaking at the collector after the manifold so I thought. I had ordered gaskets to do it ages ago. Got two sizes. Couldnt find one of them so after I got the exhaust off the manifolds, I took the gaskets and ran to two parts stores to see if I could match one up. Guess no one has sizes even close. So I was able to salvage one. The one that I had was to small. ended up finding the lost one. it was the right size. threw it on stoked as fuck to fix it. Started the car and it was leaking still... come to find out I must have some crack at the seam of the collector... oh well. maybe when I come across a welder, ill weld it on the joint and call it good. the leak isnt HORRIBLE anyway. just a bummer. At least all my collector nuts and studs didnt break taking them off.
Also noticed recently that my car and bike are unintentionally matched. The bike has been painted with tans for a while now. didnt think one day i would "accidentally" match the two....
Next week the coolant leak that I found on the throttle body is getting fixed as well.
Ugh this thing is such perfection. And btw thanks again for the hub adapter
[CENTER][url=http://www.stanceworks.com/forums/showthread.php?t=66924][color=red]e28 build thread[/color] [/url]
[img]http://i.imgur.com/hNTlNvf.jpg?2[/img]
Instagram: [url=https://instagram.com/divingboardlord/][color=red]@divingboardlord[/color][/url][/CENTER]
This mod works , but if I was you i'd get yourself the airtex in tank pump , I have the part # in my build . Lifetime warranty and is a direct plug and play. $100 off amazon .Originally posted by theseeker411 View PostLooks so good man.
What's the story with the Chevy Vega in-tank pump? I've never heard of that upgrade.
Brandon ... your car looks bad ass !!!!! I want it now.. k thanks
also I need to find my power steering leak . I'm super lazy tho... could you come over ? lol ill check the lines tho . I think its the same problem you had , feed line as all old
Ill be right thereOriginally posted by SnazzyQ View PostBring this thing up to Washington so I can shoot it scrub.
Thanks dude. Still needs a lot but im stoked on the progress. No problem! glad it went to you.Originally posted by Robitussin View PostUgh this thing is such perfection. And btw thanks again for the hub adapter
Keep it! youll regret it. Thanks man!Originally posted by fackinsteve View PostYou're making me want to keep mine, love the improvements you've made
Originally posted by 12vsex View Postalso I need to find my power steering leak . I'm super lazy tho... could you come over ? lol ill check the lines tho . I think its the same problem you had , feed line as all oldOriginally posted by 12vsex View PostThis mod works , but if I was you i'd get yourself the airtex in tank pump , I have the part # in my build . Lifetime warranty and is a direct plug and play. $100 off amazon .
Im so glad I took the time to check it and fix it. Took maybe two hours running to the parts store back and forth but so worth it. Lol your paint and body is better
Fixed my coolant leak and gave her a bath. Literally such a small gasket. Leaked on my old car and realized these two pictures may have been taken fixing the same issue. some things never change.
still love this fitment so much. still get stoked seeing it.
