I got some work done on Thursday and Sunday, but I only took one picture=/
Lets start off with the trailing arm bushings. I figured out why they will not seat. I simply installed them incorrectly. You are supposed to insert each poly piece, and then run the sleeve through the middle. I ran the outer pieces in, with the sleeve in. When I put the inner pieces in, it trapped air. This kept them from fully seating, and is now keeping me from taking them out. All I can think of now is to drill a small hole in each one to let the air escape, and then install a zerk fitting so I can grease them in the future. I will let you know how this works after Wednesday.
Now for work that actually got completed. I got sick of seeing the firewall/trans tunnel insulation just dangling there, so I finished tugging the rest of it out.
Other than that, I finished removing all of the seam sealer that I could find and also finished smoothing out the mounting points for the old ABS brackets. The next step for the bay is to weld the seams to keep any filler used from cracking. I wish I could fill every imperfection in the bay with metal, to stay away from having to use filler. That would take a whole lot of time and I would still need filler in the end to smooth it all out. Hopefully I will just need a light skim coat to fill small indents and to smooth all of the welded seams out.
