Touring International
  • Originally posted by KyleAnderson View Post
    79-93 Mustang are what you want... about 2" shorter than stock. Top mount size is the same, and lower needs about 18mm added to it (I used a bunch of washers). I'm using Strange Engineering S6000EM shocks. 10 way adjustable, and Amazon has them for $140/pair shipped. My Z is about 3/4" from laying frame with stock wheels/tires.
    Originally posted by Earl View Post
    I'll look into those=) I know a fellow 318ti.org member used 97 mustang GT shocks and they were a ton shorter.
    fyi the 79-04 shocks are the same in terms of mounting but the 94+ ones are a little bit shorter than 79-93, resulting in "an increase in bump travel and a reduction of excessive droop travel." (from maximum motorsports)
    2011 Outback 2.5i 6MT #subarubaru - daily/off-pavement adventure vehicle
    2001 BMW 325i Wagon 6MT #daswagoon - wife's #becauseracewagon
    1996 Suburban 2500 TD #superbbourbon - tow bitch/people hauler
    • I was very happy with how yesterday went.
      I finally got to order my 3" and 3.5" lips. I am so excited for them to come.
      After work I got to the shop and had just the right tool to get the pesky RTAB sleeves out.
      After a little wrestling I let out a sigh of relief as I stared at these.
      Now to reinstall them correctly this next time=D
      I grabbed these front work
      And what do you know, matching threads
      And then I did this slick move
      Tada
      I got them to screw on nice and flat=) Just need to put some loctite on the threads when I reinstall them. Now to make the top mounting coles on the frame rail.
      I also grabbed the subframe and took it in the light to see the color. Reminds me of a bass boat when there is heavy light=P
      From a distance it is just a metallic pewter color.
      The next updates will be after Saturday=)
      95 318ti & 96 328is
      Compact Build Thread
      • ooooooh that black sparkle
        @angelicmisskitty
        • I am hoping for a nice package today=) Let's hope it arrives to keep my spirits high. I just got my RTAB sleeves back from being bored out. The manufacturer forgot to machine the ID, so my bolts would not fit. All is good now.
          95 318ti & 96 328is
          • Saturday was spent waiting for a package that needed to be signed for. That package never came=/ It was late in the afternoon and I didn't feel like driving 45 minutes to the shop to do a half hour of work.
            I did end up spraying my air tank in satin clear to keep the textured paint from rubbing off.
            I also ended up removing all of these suckers from the OZ barrels:
            Hopefully the package that I was waiting on comes today. I will be ordering most of the engine parts I need to start throwing it back together after I get the timing cover off.
            I'm hoping that wednesday I can assemble and install the subframe so that I can take the car to get the bay welded up=) After that I can disassemble it again to do the wheel bearings. Yay
            95 318ti & 96 328is
            • Just placed a huge order on ECS tuning for all of the miscellaneous parts I will need in order to assemble everything=) Hopefully I didn't miss anything. The total was surprisingly only $365.
              95 318ti & 96 328is
              • Originally posted by Earl View Post
                ECS is boss!
                Damn dude this Ti is coming along very nicely! I missed the part about you getting air but I immediately caught on once I saw you modifying the control arms
                • Originally posted by Chuckdee View Post
                  ECS is boss!
                  I kept the air a secret up until literally posting pictures of the bags. I know a few people knew what I was doing when I modified my arms. It should be nice. I would have stayed static, but I just can't see spending all of this time and money getting a full respray and massaging the fenders, only to bust up the paint and make my fenders into bacon. I will still be rolling hard though=)
                  95 318ti & 96 328is
                  • Well I finally have a somewhat exciting update=)
                    Tuesday I missed a package, but did end up getting my box from Germany.
                    And the contents (plus another set of tail lights)
                    Yesterday I tackled installing the euro glovebox. Here is a comparison between the two gloveboxes.
                    I removed the metal piece under my dash to find two brackets. One was welded to the dash frame, and the other was bolted to the radio surround. Getting at the bolts for the one on the radio surround sucked. After about 15 minutes of cussing I got it off.
                    I then covered my wires under the dash and broke out the angle grinder to remove the mount from the dash frame.
                    That orange piece is another melted crayon that I found under the console. That brings the total to 3.
                    Then I quickly installed the new glovebox.
                    It needs a little tweaking, but I love it=) I also installed a new handbrake handle, but I didn't take a picture since it is nothing special.
                    I headed home after this to see if my package had arrived. Let the pictures do the talking.
                    The 3.5" lip is wider than my phone is tall=) I am very excited to get these wheels assembled and fitted. I will be sand blasting my barrels today because a scotchbrite pad wasn't working as well as I thought it would.
                    Updates to come after Saturday.
                    95 318ti & 96 328is
                    • That Euro Glovebox looks quite handy! Great stuff Earl! Also, the lips have arrived so I'm anxious to see how nicely they come together!
                      Fleet
                      '95 E36 Compact | m50tu | 3.45LSD | Autopilot V2, AirLift Performance Series (F), Air House 2 (R) - BUILD THREAD
                      '02 E39 540i Touring | Muffler Delete | Autopilot V2, AirLift Performance Series (F), RE5 (R) - BUILD THREAD
                      • wow that euro glovebox is so cool! can you post part #'s for those of us that also have trunk-impaired e36's?
                        • glove box is dope bro!!!
                          Hit me up for all your quality used bmw parts needs! http://properperformance.com/ IG: Lowlygent
                          • Originally posted by frink84 View Post
                            I should have wrote that down. I'll try to find it for you. I imported this used from Germany=)
                            95 318ti & 96 328is
                              That's not true for any brands I checked... Monroe, KYB, and Strange. 79-93 is always shorter than 94+ when comparing shocks of the same brand/type.
                              You can check for yourself here:
                                message me, I can send you one, too
                                they do have a part-no., but people mostly sell them for ridiculously high prices. Sadly there isn't a chance to get these new any more...
                                I'll just part them out on junkyards for super cheap
                                @angelicmisskitty
