How do I fix my picture problem? Will deleting other pictures on my account help?
6 into 2 does go ('74 BMW 2002 content)
I use www.imageshack.us
It's the easiest method for me, you can store up to 500 pictures per account and it's really easy to post them and it's free. I have two separate accounts because I post a lot of pictures.
indeedOriginally posted by autoE34 View Postexceeded bandwidth= bummer of marginal proportions
F**K! Now I have to rebuild my thread or some dumb s**t? Mega boner killer!
EDIT: I just upgraded to Photobucket Pro so pictures will be back up soon.Last edited by deutschman; 04-07-2012, 11:04 PM.
Yes pictures are back up! That means it is time for an update.
So my friend Jame and I finely got the steering rack in place and all aligned. We fabed up a mount for the rack (which still needs to be finish welded in place) and I started on the steering column mount, and drivers seat cross members. Today (Sunday) I plan to get the seat tacked in place, get my fat ass in it, and figure out where I want to be in relation to the steering wheel and pedals, before I finish up the steering column mounting.
Next week should bring some exciting things like actually seeing the motor in the car!
Some of my noobish MIG welding on part of the steering column mount. It is getting better all the time though.
And one of the cross members for the new seat rails.
Here is the same rack swap on some one ell's 2002 for comparison. Its a bit different in execution but same idea.
Thanks, and yes I willOriginally posted by GS-E9 View PostNice work, keep it up . see you in 4 weeks....
Today's update!
I got the steering wheel mount finished, and one of the drivers seat cross bars welded into the car. I also spent some time fiddling with my motor and just futsing around with stuff.
Tomorrow I am going to finish weld the steering rack support to the frame, weld some reinforcement back into the brake booster mounts, and close up the fire wall, and then paint it all. That way I can get the motor in place on Tuesday.
Did some more work today. I got my ear support fabricated and welded in place (still waiting on the aluminum rad from Summit to come in...), got the oil cooler mounted up, and closed up the gaping hole around the steering column. I think we are going to start test fitting the engine and trans tomorrow. I'm excited for that!
I riveted a piece of rubber tube under the oil cooler to keep it from clacking around and scraping the paint off the frame rail.
what exactly did you paint the engine bay with? It looks to me like you brushed it on or something, and it's pretty much the same look that I'm going for. I bought some Herculiner truck bed liner which I plan on painting all my wheel wells, floor pans, trunk area and engine bay with and it's a brush on application. Wondering now if what you used would be better for the engine bay considering it might get too hot in there for the bed liner stuff. Nice progress!
Did not get much done today. We were going to try and get the engine in the car but it turns out I do not have the right bolts for the trans to bolt to the block. So Blunt is sending them my way tomorrow. Until they show up we are kind of dead in the water. I have a few small things to do hear and there but not much till that dam motor is in.
I did get this in the mail today. 22" wide by 19" high aluminum dual core radiator. It should keep the m20 frosty.
We did get the fly wheel on along with new rear main seals and a pilot bearing.
I got the diff mounted up and filled with fluid as well but everyone has seen that done before so no pictures.
Welp we finely hit a bump in the road. The pilot bearing inside diameter is to small for the input shaft of the trans. Spent about three hours trying to stuff the trans on today thinking that it was just the alignment of the clutch and bearing. Finely took everything apart again and found the bearing is the wrong size. Ordered new ones from Blunttech. I am going to take a day off of working on the car. I need to step away for a bit and do something ells.
taking breaks is good, you'll burn yourself out otherwise. I haven't worked on my car since last friday, and I was honestly feeling a bit worn out and was losing motivation. I get to go work on my car again this upcoming friday and I'm super excited and can't wait to get back on it!Originally posted by deutschman View PostWelp we finely hit a bump in the road. The pilot bearing inside diameter is to small for the input shaft of the trans. Spent about three hours trying to stuff the trans on today thinking that it was just the alignment of the clutch and bearing. Finely took everything apart again and found the bearing is the wrong size. Ordered new ones from Blunttech. I am going to take a day off of working on the car. I need to step away for a bit and do something ells.
Got a few small things done today. Still waiting on my dam pilot bearing to show up at the door.
I got the passenger seat rails all welded in, painted and installed the gas tank with the 318i fuel pump and Auto Meter fuel level censor, I got the fire wall all patched up with the brake master cylinder, and fit the exhaust a bit.
