So if I pull a leaf out and keep my 3" blocks for 5" of total drop. Is it ok to not have angled blocks?
Stanced Trucks?
Originally posted by MitsuMax View PostSo if I pull a leaf out and keep my 3" blocks for 5" of total drop. Is it ok to not have angled blocks?
no such thing as 5" blocks and if there is then they shouldn't be any where a vehicle
the 4.3's are good, i have the TBI and CPI and the cpi has a lot more power
Originally posted by Wildman Productions View Postyou'll have to measure your pinion angle before and after to determine if you will need shims or not
Originally posted by MitsuMax View PostSorry for being a noob but how do you measure the pinion angle?
angle finders are about $5
you can usually eyeball it to around where it should be
Originally posted by Wildman Productions View Posthttp://www.ssz28.com/tech/Pinionangle.html
Also, I currently have the 97-04 3" drop springs, and 97-04 2" drop spindles, and 97-04 3" drop leaf springs... if I end up buying a 94-96 model (not the older boxy one, but the first gen of your body style) will those parts bolt in correctly?| 92 Corolla AE92 | HKS SMF, Testpipe, Hyperco/Tokico/GC | Houston, TX | 86Garage |
Originally posted by kaidotech View PostOkay so let me get this straight.... if I buy an extended cab then I'll have the crossmember issue... Im assuming if I get the 4.3L I'll have a Y-pipe issue.
the springs, spindles and leaf springs are swappable on all years of s10's, from 83-04
95-97 blazer have different leaf springs, and 98+ blazers have different spindles and leaf springs
Sooo..a hidden pothole got in the way while I was turning into a parking lot and screwed up my toe angle and now I have a bald tire, even worse it is now flat. Soo I have to use my other car for now until I get that fixed. Might as well take out the middle leaf spring while I'm at it.
Originally posted by MitsuMax View PostSooo..a hidden pothole got in the way while I was turning into a parking lot and screwed up my toe angle and now I have a bald tire, even worse it is now flat. Soo I have to use my other car for now until I get that fixed. Might as well take out the middle leaf spring while I'm at it.| 92 Corolla AE92 | HKS SMF, Testpipe, Hyperco/Tokico/GC | Houston, TX | 86Garage |
they're corvette rally's
another pic since the blazer was clean after the My Ride Rules audition
IMG_3890 copy by B Wildman Photography, on Flickr
Originally posted by way2fastx3 View PostWhere did you pick up the Roof Rack for the sonoma?
IMG_4024 copy by B Wildman Photography, on Flickr
