It's not a complete bolt on kit, there's a guy (ricksrangerz) that makes the coil buckets, c notch, radius arm mounts, and trans cross member. Lots of grinding and drilling out heat rivets and frame mounts. His coil buckets are made for a couple different coilover setups but I went with a small qa1 coilover and swift spring, his other stuff is mostly for bagged trucks. The rest of it was fabrication and figuring out what would work. Basically I'd lower it, hit something, and have to cut or clearance and the process went on and on. For example the drive shaft hit the bed and fuel tank cross members and I cut the fuel tank cross member out and built a new bed cross member since I'm running a fuel cell now. I had someones help to figure out super beetle air shocks fit in the rear with different bushings. The wheels are 15x10 et -38 and tires are 195/50s.
Untitled by Cole Hannah, on Flickr
