LS2 Dogbox FC swap
  • #31
    This is fucking awesome, I'm subscribing to this, you better up date it with tons of pictures and videos!!!!!!!!!!!!!!!!
    1988 Toyota MR2 Supercharged
    Stance:Nation Feature | Build Thread
    • #32
      awesome build...subscribed
      • #33
        yeah, what an epic build! great to see this!
        if i understand well it takes 3 years to be done?
        • #34
          nah 3 years worth of planning and funds... looking for the right chassis -just really took my time -did all the labor on my own while working full time/married life... it is far from "done" -but at least is drivable.
          Originally posted by Royal_T View Post
          So what would you do different? cause in my opinion I think that is the perfect setup.. Might do the same..
          As far as the intake rad set-up I would probly go with a smaller dual pass rad that could be mounted vertically and still leave enough room for the intake to come over the top.
          • #35
            So you can't mount a dual pass rad the way you did? Well build looks good bro,
            • #36
              Nah you can -just no need -with a dual pass you can run something smaller and get just as good -if not better cooling.
              • #37
                thats a sick project. cant wait to see it run.
                • #38
                  Originally posted by cheez80 View Post
                  epic
                  this.
                  http://rivalhousegarage.com/
                  rivalhousegarage@gmail.com
                  • #39
                    Engine is toast -not sure why but it chewed up the bearings -I had put maybe one mile on it. Started a complete tear down of the motor. FML
                    Oil looking bad:
                    From Rod on #1
                    looks like I need a new crank, rod and pistons -maybe cam as well...
                    • #40
                      I was like YAAAAY updates on this sick car, and i come to see this? makes me sad.
                      Looks like it could be a bad oil pump, but you mentioned it only had 2000miles on it. How you can find the reason for this, so you can get it back up running.
                      -Instagram@jdjurhuus
                      Stretchsaurus and Pokemon.
                      • #41
                        Winter bro, was going to start in Oct but things came up so winter begins the build.. I'm actually building it now just the motor, heads, big cams, FAST 102 ect.......... going to be a beast..
                        Cant wait
                        [B]Oil looking bad:
                        So sorry to hear dude... I **** when setbacks arise, They are the mother of all fuckers.
                        Hopefully you can work something out soonish dude..
                        Originally posted by anth
                        • #42
                          I'm going to look at a few longblocks today -an LS1 and a L33 -both under $500 -I'll drop that in for now and build the LS2
                          I'm thinking the failure is my fault -I blasted the pan and as it turns out I guess that is a no no.... material prob got stuck in the walls of the pan and came out when it got hot... FML expensive lesson.
                          • #43
                            Man that sux but also cool tht your going to build the LS2.
                            Hey if you don't mind me asking. How much was your Howe's Rad. Plan on using them to make my rad.
                            • #44
                              Ls1 would be the best option wouldnt it? Wouldnt have to change anything to get it in there and running right?
                              • #45
                                If I get a truck motor I already have everything to make the swap -so it really does not matter
