Another E36 build
  • #61
    Im working on some widebody overfenders for the cupe at the moment, but its going to be one color some time during the winter
    http://www.stanceworks.com/forums/sh...=55145&page=99
    • #62
      in for more, awesome that you're doing all of this
      • #63
        First of Great news!
        Im finally getting a workshop!!
        flares are taking shape as well. not 100% satisfied with how they look yet, but its not to far off. 50mm over stock.
        Im getting some 25mm spacers to go on as well so it'll be proper wide
        • #64
          Had some more foam left sooo
          • #65
            Now this is dope! keep it up man.
            E36 Bonnie
            • #66
              What kind of foam is this man?
              • #67
                Originally posted by Tim Holm View Post
                More picures from the baning
                quick test fit on the compact
                Two down, just waiting for the paint to dry now. Ill be running 20565 winter tires on these for now. would probably look beter with som lower profile but thats what I got at the moment.
                Did you buy the metal in the bands or did you have to make the bands?
                How thick are the bands?
                Did you weld the inside and outside of the bands? If you welded just the inside what did you do to fill the imperfections on the outside?
                Sorry for all the questions but I am really intrigued by your build!
                • #68
                  Thanks man
                  Its just builders foam, they use it around windows and stuff. Id like to get some pour able self expanding stuff but I haven't been able to find it anywhere yet
                  I got them cut to witdht where I bought the metal, they have a huge machine for it.
                  you can probably get them to roll it as well, its really important to have them at about the right curve
                  for these 15" they where 2" wide and 3mm thick, the 17"s where 3" wide and 3mm thick
                  I only weld the outside, but use enough heat so it burns allmost all the way trough,
                  Usually I can just grind over the welds inside the lip with a sanding disk and it looks fine, might use some tin on the new ones though
                  Finaly got the spacers today :O
                  [/url]
                  And I passed my motorcycle drivers test so now I can actually drive it legaly :P
                  • #69
                    Oh yea, and parts
                    KDFI engiene management
                    Custom made cam locking tool for running double nonvanos intake cams Made by T-Parts. check his site out btw, great guy https://www.facebook.com/tpartss
                    ARP studs
                    630cc Simens Deka injectors
                    And a Athena cutring gasket
                    • #70
                      started moving into the workshop today!
                      [/url]
                      and more or less done with one fender
                      [/url]
                      • #71
                        progress on the new shop
                        • #72
                          Sweet time lapse on painting the shop. Can't wait to see what you build there.
                          http://www.neuemotorsports.com/
                          • #73
                            Duuuuuuude that new shop is fucking sweet. im super jealous
                            • #74
                              I think its done. Polishing and probably casting tomorrow
                              • #75
                                cant wait to see how this turns out :O will peal it off in the morning
