Lots of really neat stuff!!! Love the widened wheel! The LSB bumper looks great!
Another E36 build
-Christian.
Thanks man, om banding a set for the compact to use as winter wheels. This is my first attempt so hope it's not to shaky once I get it on the car.
Got my brother cuting the rims
before and after
Got a winter tire mounted with some butane and a lighter, 205\65\15 on an 9" wide rim
doing the next 2 tomorow or one of these days
Btw the wheels where pretty good actually, does woble a little around 80kph, but these rims did that before as well.
Im getting them balanced as soon as ive done all of them anyways, but its suprisingly easy to get this rightLast edited by Tim Holm; 01-11-2015, 01:11 PM.
I was planing on taking the 325 to Gatebil on ice, but its acting up. seemes to be a missfire on nr 4. coil plug and injector are all good so must be a lifter or someting.
but because thats not runing properly I desided to prep the 316..
got these angle adaptors as well but I dindet have time to mount them, so just stock 316 with welded diff
they posted this video just now. its mostly norwegian but you get the idea
Gatebil On Ice @ Hebbe Isbane 2015 from Gatebil on Vimeo.
was my first time on ice, and first time drifting the compact so lots of challenges
silver supra is Fredrik Aasbø
I had one off and smshed my fog light and lost the lisense plate but thats not to bad I think.
Im kinda glad I went with the 316. one fueltank for the full day. even had a little left when i got back home
here it is back from the trip. its about 5 hours drive each way so we left around 4 in the morning and got back around 11 at night
IMG_20150125_131755 by Tim Holm, on Flickr
I bhought another engine from a guy up there. its another m50b25nv and it has a ZF gearbox
was a terribe job geting it into the car but out was pretty easy
har desverre ikke noe sted å stå jeg heller, men har leid plass til bobla så sniker meg inn der når været blir for kipt :P
tore down the parts engine, looks like what happened was that one of the rod bolts snapped, and then the other one bent and the crank pushed the rod trough the block
Im using the head and getting the intake cam moded to fit the exhaust side, then im swaping over the intake cam from the engine in the car to this one when im swaping engiens
IMG_20150128_144530 by Tim Holm, on Flickr
IMG_20150128_150103 by Tim Holm, on Flickr
IMG_20150128_163106 by Tim Holm, on Flickr
IMG_20150128_171546 by Tim Holm, on Flickr
IMG_20150128_171528 by Tim Holm, on Flickr
IMG_20150128_172942 by Tim Holm, on Flickr
IMG_20150128_163131 by Tim Holm, on Flickr
IMG_20150125_012247 by Tim Holm, on Flickr
IMG_20150128_164537 by Tim Holm, on Flickr
AND fucking finally I got around to banding the 17" wheels. 3" band.
225\45\17 11" wide. Im considering a 4" band on the rear wheels now. I think i probably could make it work.
IMG_20150208_211543 by Tim Holm, on Flickr
here it is pre rolling. its sitting on the rubber
IMG_20150211_185437 by Tim Holm, on Flickr
slight roll in the front
IMG_20150213_204253 by Tim Holm, on Flickr
cut the lip and rolled it so it almost clears the rubber, still need some more work
IMG_20150215_153542 by Tim Holm, on Flickr
IMG_20150215_154010 by Tim Holm, on Flickr
post roll and cut rear. its really rough but Im going to go over it with tin and smooth it out
IMG_20150215_170328 by Tim Holm, on Flickr
post roll in front, I can still go a little lower here i think. should be able to remove the adjusters or one of the springs in the coilover but that might affect handeling to much
IMG_20150215_170239 by Tim Holm, on Flickr
IMG_20150215_170228 by Tim Holm, on Flickr
IMG_20150215_170157 by Tim Holm, on Flickr
where did you get them angle adapters!!!IG: Dimitriantoniou
1997 bmw 328i vert: sold:http://www.stanceworks.com/forums/sh...ad.php?t=55235
1997 bmw 328is: http://www.stanceworks.com/forums/showthread.php?t=69857
Thanks guys
Meech I got the adaptors from here http://www.t-parts.se/produkt/styrvinkel-adapter-e36/
if you combine them with some rackspacers you get some pretty good steering angle and response
love everything in here
i would love some 17x11 steeliesSugar Mama Build - http://www.stanceworks.com/forums/sh...ad.php?t=73298
