DER E30 will do man
we got some plans with drones and a bunch of gopro cams
shifter and hydro installed on the 370 ls7 e36
you can follow his build on here https://www.facebook.com/M.Larsen.Drifting
IMG_20160110_151230 by Tim Holm, on Flickr
IMG_20160110_151251 by Tim Holm, on Flickr
IMG_20160110_151303 by Tim Holm, on Flickr
IMG_20160110_151310 by Tim Holm, on Flickr
we decided that the front wheels where poking to far out on the beetle so I had to make a new front bream for it..
this should give 4" of adjustment, and we are placing it so that it starts from stock height.
+ we have 2.5" drop spindles so a total of 7.5" lower than stock
should be good
I couldent find any good guides for how to do it so Im trying to figure it out as I go but this cut-off gives a pretty good idea
received_10206068611497582 by
front_axle_section4 by Tim Holm, on Flickr
First I cut out the center anchor out
IMG_20160128_160558 by
IMG_20160128_160739 by
I cut two Inches out of ether side of the bar, the reason I wanted to do it this way it so end up with as clean a bar as posible when done. this way I wont get any welds on it other than the stock ones.
IMG_20160128_160642 by Tim Holm, on Flickr
ended up making some wider sleeves so I wouldn't get in trouble with movement after welding it up
IMG_20160128_200603 by Tim Holm, on Flickr
then I placed the inner one of the toothed adjuster plates on the beam and used it to mark where to cut so Id get a straight cut all the way around.
I used the pieces I cut from the sides to make a sleve for the adjuster
IMG_20160128_210832 by Tim Holm, on Flickr
thats as far as I got today, working on the bash bar for the 370 as well so progress i slow on the beetle.
Ive got to widen some wheels for it as well, should get that done next week and then its time for paint
here are the numbers on my engien btw for anyone interested.
IMG_20160123_170346 by Tim Holm, on Flickr
we got some plans with drones and a bunch of gopro camsshifter and hydro installed on the 370 ls7 e36
IMG_20160110_151310 by Tim Holm, on Flickrwe decided that the front wheels where poking to far out on the beetle so I had to make a new front bream for it..
should be goodI couldent find any good guides for how to do it so Im trying to figure it out as I go but this cut-off gives a pretty good idea
front_axle_section4 by Tim Holm, on FlickrFirst I cut out the center anchor out
IMG_20160128_160739 byI cut two Inches out of ether side of the bar, the reason I wanted to do it this way it so end up with as clean a bar as posible when done. this way I wont get any welds on it other than the stock ones.
IMG_20160128_160642 by Tim Holm, on Flickrended up making some wider sleeves so I wouldn't get in trouble with movement after welding it up
IMG_20160128_200603 by Tim Holm, on Flickrthen I placed the inner one of the toothed adjuster plates on the beam and used it to mark where to cut so Id get a straight cut all the way around.
IMG_20160128_210832 by Tim Holm, on Flickrthats as far as I got today, working on the bash bar for the 370 as well so progress i slow on the beetle.
