Man looks so good! You need to get those wheels coated so you can just hose the brake dust off.
Never ending quest of badassery
Originally posted by UpperClass View PostMan looks so good! You need to get those wheels coated so you can just hose the brake dust off.IG: @dubsesed
"All is fair in love and low"
Lowered Values
PVW 5/15
IG: @dubsesed
Lowered Values
PVW 5/15
Dis is gud!1
Very nice work, nice numbers from the engine. These kind of cars is allways big+. I want to see more of this kind of builds and cars.
Car looked great at Sowo. I looked over the bay got a good bit
Well, the car made the drive to Michigan and back over the weekend for Eurohangar. On the way down it was crappy weather the whole drive and I forgot to empty my catch can before we left so it was pissing oil over everything the entire drive there.. I hadn't re-installed the baffles on top of the cams when I put everything together so that has been kicking quite a bit of extra oil into the can. I'll have to fix that soon.
Some pictures I was sent by @ebaunics. I'm sure most of you are familiar with his MK4.. If not, check him out!
My potato contribution:
The car got best of show which was a complete surprise as there were plenty of spectacular vehicles there! I think the final count was 560 cars.
On the way home my wastegate rattled loose near Madison Wisconsin, so I had to tighten that back up. Boy was that fun! It was a good thing after all, since I discovered the OEM braided line I used for all my vacuum line was cooked pretty bad and just disintegrated when I tightened the WG back down. I'm going to make a nice stainless hardline so I won't have to worry about that anymore.
Other than the catch can and the Wastegate issue it went off without a hitch. I even hit boost for the first time in 5th gear.. That was interesting. Now I know the FX400 will hold full boost at 2500 RPM and the shaved sidewalls didn't mind 160+..
Monday came around and I got my CCW's I ordered for my daily 2010 Jetta sportwagen. Boy oh boy are they perfect.. Also ordered new Broadway Static coilovers for it that will be here Thursday. So much for having a comfy daily. I got tires mounted today but didn't take any pictures.
Also, my neighbor and fellow member of Eurowerks has a little side gig making these into shirts and high quality prints. He's making some of my car for the upcoming show along with some other noteworthy local vehicles. He'll do anything you want and it's super reasonably priced! His contact info on IG is @autoillustrated. Go check him out!!
IG: @dubsesed
Lowered Values
PVW 5/15
