Most of my ideas end up with a car, big metal chain, and welding it to a work bench. I mean you could always weld a tab, but might as well just make a clean cut around it at the bottom pull it out and reweld it. I would try a lot more heat and something strapped to the slide weight (like a sledge hammer) 02's suck. If you do weld it, make sure you take your time and get a nice seam and have it perfectly straight. I would grind down the weld after that and weld a collar around the point you welded, just to be positive... if you're not 100% on your welding.
Back from death- the revival of a 74 BMW 2002
So after spending 9 hours straight on the 02 today, I managed to nearly finish the driver side rear fender. The rear fenders take so much time to make smooth and look right. I also sanded down the back of the car and layed a few coats of primer. With h2oi officially 60 days away, I'm going to need to push hard to finish her. More work to be done tomorrow night after work.
Originally posted by rhoderacer View PostSo after spending 9 hours straight on the 02 today, I managed to nearly finish the driver side rear fender. The rear fenders take so much time to make smooth and look right. I also sanded down the back of the car and layed a few coats of primer. With h2oi officially 60 days away, I'm going to need to push hard to finish her. More work to be done tomorrow night after work.
You and I both have a lot to do before H2o...
Nice progress, sucks about the ER visit, gotta love how life throws you shit when you have stuff to get done.
started the week like this
ended the day like this
the rear fender needs a little more work but I'm happy with the progress. I also managed to weld in the sunroof and get the trunk lid finished. I dropped the driveshaft today to replace the clutch. Surprisingly there were no stubborn bolts. tomorrow I can pull the tranny and swap out the clutch.
All moved in. A couple friends and I decided to rent out a old mill to keep all of our projects in one place. I love the size of the building and the rustic feel it has.
my 02 next to the 240 rb25det and 74 Datsun 260z.
Across the building, a square tail is awaiting a restoration. kind of weird that 2 76 2002s are under the same roof.
