Now that I got all the drivetrain locked with the production mounts, I was able to install the driveshaft tunnel, and it wasnt hard at all.. I left all the bottom support of the closed driveshaft tunnel, so I only actually had to go up a bit, and the body integrity didnt change due to removal of factory braces.. You can see how it all lays out here, but I still have some finish welding to do, and as you can see I like to add some bar/strap to the weld points for some extra bracing.. It is a pretty simple addition, and I think it just gives me a bit more piece of mind, and I think it also looks better when it is all finished up.
The Datsun seats that I am using are narrower than the oem Amazon seats, so I actually needed to move them 2in away from the center, and that centers everything to the column and guages perfectly. I really like the fit of these seats, because they dont look like they are stuffed in there, and have nice trans tunnel and door gapping, for a factory look.
