Saving a Porsche. Vr6 Turbo power
  • Cooling issues were my biggest set backs too. Good luck with hashing it all out.
    • finally found the last leak
      If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
      follow on IG: eurotrashapparel
      • thumbs up
        YOUNGIN // DESIGNER // LOOKING FOR LITTLE JOBS AND WILL WORK FOR NEXT TO NOTHING // LOGOS, STICKERS, SIGNATURES, WATERMARKS, POSTERS, ADVERTISEMENTS, ANYTHING // PM ME // YOU WONT REGRET IT
        • This is so fucking cool! I love the camo
          Insta: @pantiesmores
          • awesome build man keep the pics coming.
            PORSCHE
            • sweet lord almighty.
              H A R D P A R K E D "Just For Looks"
              • Just awesome
                Build Thread:Bagged Integra Type R DC2.
                • Thanks guys. I think i have a bad head gasket as it appears im leaking coolant between the head and block when under boost. this was just a stock block, no head gasket or studs so its not surprising.
                  as it sits now.
                  • Hey, at least it looks pretty sitting.
                    Originally posted by Longboarding_G
                    you sir, win this battle.
                    “Producing something of quality is obsessing over details nobody sees.”
                    • Good job. Looks great.
                      • well did a compression test, everything checked out there so i built a little fitting to pressurize my coolant system to see if i could force it out while not running. the fitting i made to bleed off to rad was the problem . so good news there but bad news as car was still lacking boost so back to trouble shooting. when i would get on it it lacked any real turbo feel, more linear power. sometimes smoke from tail pipes, sometimes just from turbo housing, sometimes just at long idle, sometimes not at all. after i took it out for a warm up run i brought it back and seen the smoke coming from turbo. oil was leaking onto the housing. looking around there is where i found a lot of shaft play. looking online i have found the holset needs a larger drain line than most. i had to make a angled drain fitting to clear the compressor housing and i knew it was the issue. need to figure that out and i ordered a turbo rebuild kit. now i would say that it should be good to go after that but i've let myself down to many times
                        • dat exhaust doe....
                          • I need to stop looking at this thread, it makes me miss my 911.
                            -Darrick
                            Frankenbike Build Thread
                            Another Frankenbike Build
                            • Great work, way to bring her back!
                              • looks good.
                                hope you get it sorted sooner than later.
                                i despise my car, capital letters, and probably you.
                                IG doktor_b
