Still have a soft spot for those. Owned a pickup, an Innocenti saloon and a Rover saloon. Hurry up, wanna see the final result.
1991 Mini - Project Trig
My 1978 Porsche 924 build thread is quite boring.
STRLW // Photography focused on vehicles
So a weeeeee update for you all! With failure of electrics Ive not had much else to do on it but got some done anyway.
I test fitted my tank and then bootlid at the same time and immediately struck a problem. The lid hit the tank with its internal hinges! Megafail! So I took the tank to Kirkton MBR to get it modified (again)
Didnt need much, just a couple of inches and it clears.
However! The strap that holds it in place now fouls the hinge! So I modded that too....
Bent into a passable state...
It still hits, so needs more modding/bending. Its getting close though.
Once its done the tank needs sealed, fillered and smoothed. Lot of work but worth it!
So I fixed on my latch and got the lid fitted. ITs a crooked fit so need to bend the hinges about a bit to get it sitting nicely and the boot seal is stiff and almost preventing the lid form closing. Need to try and soften it up a bit.
I covered the bit of paint where the pin goes into the latch with a bit of 1mm thick Laminex I had sitting about. Prevents scratching and indeed rust!
Today we got some upholstery work done! I have a theme of black suede and vinyl so got loads of both materials and let my mum loose on them! The results have been brilliant!
Suede cloth....
We got the dash rails done today but no photos yet as they arent finished and need trimmed. VERY happy with them though!
Also got my headlining (black suede too) in, just need to do the tricky bit of sticking the edges to the roof. Nightmare of a job so waiting for more hands on deck for that one.
Oh and I got the car featured in the P&J 'Your Car' section today too! Great little write up and great to see the car in print too! First feature of many I hope.......
So tomorrow is wiring and more upholsteringProgressing again!
Small update. Got my bonnetI am most pleased with it
Sharp colour change line which you cant feel. Epic paintwork!
and dropped in place for a test. One shiny motor!
Looks a bit lost with no grille/grille surround but that will come once the dam electrics are all done.
And a reflection shot just for fun...
It has a unique paintjob underneath but that wont be revealed until show season 2013
OK so the last couple of days we have been busy with the interior bits. First up, finish off the dash rails.
We kept on sticking a bit down, leaving it for a day or two then repeating as we went. Clamped on with clothes pegs as the adhesive dried.
So thats them done now. Very happy with the final outcome.
Top one is easier as it is a metal piece covered in foam whereas the bottom is pure foam. More flexible but not impossible to cover.
Then we started on my doorcards. For these Im going diamond stitch suede with leatherette too. This thing is turning into a luxury barge! I want the cards to be slightly padded for added looks and luxury so we bought some wadding to do the job.
So here we have some black cotton sheeting, wadding then the alcantara. The black sheeting is so the wadding doesn't get caught up in the sewing machine.
Then we tacked it all out so the material wouldnt move as we sewed.
We used double thickness wadding for more defined diamonds but this led to the machine struggling and as a result slightly squint lines. We werent happy with this so unpicked it all and we are now resorting to single thickness.
Sickened by that we moved onto the headlining. Out of the frying pan, into the fire as it turned out to be.....
So the headlining was put in and left to hang.
When we rotated the hangers to their upright positions they caught on the material and twisted it. So we removed them again and I set to work with the polishing wheel to make sure they were properly smooth.
Then we reassembled and eventually got the hangers to stay upright after placing foam between the hanger and roof to 'lock' them in place.
As it happened its dam tricky doing a Mini headlining, so we got one edge (the back window) done before we called it a day, to leave this to set. I hammered on a boot seal to the lip to hold it on the glue on both sides. A handy tip I found online!
Whilst my mum and I were doing this my dad was smoothing off the fuel tank. This was pre sanding so doesn't look like this now!!!
So its almost ready for paint now! Just need to buy tank sealer to pretty much make a tank within a tank so there is no chance of leaks.
Back to work for the next 7 days solid again so will try and get a few little things done in the evenings when i have time.
Originally posted by ak-47 View PostThanks for the awesome write up and pictures!
So not much progress as I have been working mad hours at work to rack up the overtime! Means I am tired 24/7 but worth it at the end of the month!
Decided to fill and bleed my brakes. Got all the unions properly tightened, poured in fluid and found a rear one was leaking. Turns out the brass end had cross threaded so ordered up some more from eBay along with a flaring tool so I can remove and then reflare the pipe.
Just using this stuff as its not a performance car.
Mum has also been busy working away at the sewing machine.....
and I have now got all my missing tinted glass after finding P&L Minis have a handful of new old stock Rover panes in stock! Thankfully they post too!
So heres a drivers pane by pilkington so its a late '90s window. As its drivers side Im now going to have to disassemble my drivers door to swap the glass over. Annoying but better to have the perfect window on the drivers side!
They also had 10 non opening rear windows in the factory tint in stock too! They now have 8Should arrive tomorrow or day after.
Hedlining is getting finalised at the weekend and then the windows will go in and I will get the brakes bled and tank finished off, painted and installed. Then it really is just electrics to do!
