Senza pari 280z build
Did you consider, or is it even possible, to put in deep tubs in the rear with an extremely shortened axle to get the rears to stuff under those stock fenders? But I guess you'd still have had the super wide track out front unless you when skinnier up there. Just asking, but regardless this will be jaw dropping. I like where this is going. Any teasers as to the final color of the car?"Strive for perfection in everything you do. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
Sir Henry Royce, Rolls-Royce Motor Co.
The past few weeks have been been spent finishing up customer cars, which doesn't leave much time for the Z, but it's all good stuff so I can never complain...
IMAG0933 by SENZA PARI #1, on Flickr
IMAG0937 by SENZA PARI #1, on Flickr
IMAG0939 by SENZA PARI #1, on Flickr
We were able to put the Z on a diet the other night however, and progress is starting to happen...
Meet Ross. Been working together for 10+ years, and a best friend for going on 20. Also the owner of the Texas Mile Rx7 seen in the other thread.
IMAG0952 by SENZA PARI #1, on Flickr
IMAG0950 by SENZA PARI #1, on Flickr
IMAG0961 by SENZA PARI #1, on Flickr
IMAG0957 by SENZA PARI #1, on Flickr
IMAG0963 by SENZA PARI #1, on Flickr
IMAG0965 by SENZA PARI #1, on Flickr
IMAG0967 by SENZA PARI #1, on Flickr
IMAG0968 by SENZA PARI #1, on Flickr
Having removed the front end and floor pan, I can start to see things a bit more clearly. The T-square represents the line of the main hoop of the roll cage... it will be 90 degrees from the frame, as apposed to laying back at 5-10. This will strengthen the cockpit, simplify the layout, and push the rear wheels back by about 5-6" on center. The front wheels also get pushed forward about 10", for an overall wheelbase of around 105"+/-, vs. the stock 90.4". This makes for a much more stable ride at speed, and a bit more predictable/progressive in the corners. The height in these photos is still about 1.375" higher than it will be once complete.
The back end/floor/strut towers will be cut away this weekend, all measurements will be verified, and the new frame/roll cage will begin.SENZA PARI
SENZA PARI by SENZA PARI #1, on Flickr
Flickr Album:
http://www.flickr.com/photos/74953263@N07/
Instagram@jdjurhuus
