holy shit! I'm hard.....
Senza pari 280z build
Lucas
again, i am speechless. cant wait to see the body go through the major changessigpic
1982 euro porsche 930 turbo
Ditto!Originally posted by loekaaz View Postholy shit! I'm hard.....
Thanks! Neither can I...Originally posted by 1badg35 View Postagain, i am speechless. cant wait to see the body go through the major changes
Both, but primarily track/road. Road America is about an hour away and I attend the open track days quite often, so this is where it'll be broken in most. That and the highways of Wisconsin/Chicago/Mnpls.Originally posted by rturbo 930 View PostSo what are your plans for the car? Track car? Show car? A bit of both?
Ha, as it is, just about that!Originally posted by ZammoTheChoppa View Post1/28 wheel turn lock to lock for 7Degs of turn LOL :P
looks seriousSENZA PARI
SENZA PARI by SENZA PARI #1, on Flickr
Flickr Album:
http://www.flickr.com/photos/74953263@N07/
I think that was for leak testing.Originally posted by CrazyCripple View PostI really like watching what is going on in here. BUT! Can somebody please explain to me the welding of pipes. Exactly the part where the end is covered with foil or tape or some cap with a fitting and a hose.
VOriginally posted by CrazyCripple View PostI really like watching what is going on in here. BUT! Can somebody please explain to me the welding of pipes. Exactly the part where the end is covered with foil or tape or some cap with a fitting and a hose.
Correct... when purging with argon all opens ends are capped or sealed off. The argon enters the workpiece through the green hose you see in most photos.Originally posted by benfer View PostI believe it is for holding the purging gasses in while welding.SENZA PARI
Flickr Album:
Originally posted by benfer View PostI believe it is for holding the purging gasses in while welding.thank you for the correction and info. :thumbsupOriginally posted by SENZA PARI View PostV
My god, this is one of the coolest builds I've ever had the pleasure of reading/watching come together. You are quite a skilled guy!
I can't wait to see where you go next
1997 BMW 328is Alpine White // Dove Grey
ZF Swapped | 3.23 LSD | FK Coilovers | 17x8.5 Borbet Type C | 75mm Wheel Studs | 12mm Vorshlag Spacers | 5000k HIDs | Euro Taillights | Suede Headliner/Pillars
A little bit of scribbling... frame revisions and suspension layout brainZtorming.
IMAG0801 by SENZA PARI #1, on Flickr
True to form, I always start out with some elaborate design which is more often than not overly complicated or nearly impossible to actually manufacture... or just not cost effective. So, after I beat myself up about how to go about cutting/bending/welding whatever it might be, or how I'll have to tweak or change other things to deal with the possible fit-up issue... or again, whatever the case might be... I'll get my head out of my *ss and simply change it, and the result is always possitive. You think I'd learn!Last edited by SENZA PARI; 03-21-2012, 09:46 PM.SENZA PARI
Flickr Album:
