Originally posted by 1988montecarloss
View Post
Satchealous Garage Mk1 rabbit
Had a productive day, don't mind the shitty blackberry photos though.
I'm still finding some rusty spots here and there in the engine bay. I cut out this spot on the front panel.
Front and back all patched up
Covered up with some high-build primer
I got all caught up trying to make everything perfect in the engine bay but then I remembered I'm not building a show car... I began sanding and spraying some primer here and there and it's already looking a lot better. There's still some metal work to be done but it's getting there.
My buddy Jon set up this wheel spinning rig. We weren't sure how it would work out but it made polishing the wheels super easy.
Wheels all masked up and primed
And donejust need to spray some clear
Thanks guys
Some more shots... Need to go lower but I wanted to see what the lowest height with helpers looked like. Front fenders need a good pull to make the poke look a little less silly and the rears could use a roll. The front wheels need a spacer to clear the brakes but the smallest one I have is a 7mm. I might be able to get away with something smaller.
