Originally posted by aaron22
View Post
Satchealous Garage Mk1 rabbit
nice work Aaron, seems to be going in a similar direction as my build (in the way that everythings getting done at once) Can't wait to see this thing in person
good to c some more progress on tisFloccinaucinihilipilification
Great great build! So youre using a 9A block with a KR head right? What are you expecting for hp output with the zx carbs? Engine is looking damn fine..it will be a beast!
My buddys running a 1,8 KR with 45 double Webers in his MK1 with about 160 whp so im sure yours will be fast as fuck!!
Keep up the good work man!
Oh, thats his car btw
slamburglars.com
Thanks errbody
Thanks man, looks like your e30 is coming along nicely tooOriginally posted by EuroNut View Postnice work Aaron, seems to be going in a similar direction as my build (in the way that everythings getting done at once) Can't wait to see this thing in person
Yep, 9a/kr hybrid. Don't think I'll be making quite that much but ~145ish would be awesome. With the exception of the header and carbs, it's all stock. I bought the head already rebuilt and the bottom end is a mystery block. I pulled an entire 2.0 from a passat at a "carry out what you can for $50" parts day at a scrap yard. I tied a seatbelt to the latch of an upside down car hood, threw the entire motor, some extra manifolds, and more onto the hood and dragged that bitch outta thereOriginally posted by G535 View PostGreat great build! So youre using a 9A block with a KR head right? What are you expecting for hp output with the zx carbs? Engine is looking damn fine..it will be a beast!
$50 engines FTW
$50 engines FTW
Haha, nice to hear what you can get for such a small amount of money! 50€ wont get you shit in Germany though we have shit tons of old passats and golfs...
Anyways, except for the carbs my buddy's not running anything too special and it still runs good. He's got different cams, lighened flywheel, no cat, bigger exhaust and some other minor stuff for reliability. The set-up's been lasting for the past for years without a single problem and that thing gets driven hard.
At least the sound of your engine will be badass im sure
slamburglars.com
Back from the dead with only minor updates. I ran out of money and never did end up buying those keizers so I've decided to refinish my exims. The other week I grabbed a used set of 175/60r13's. As much as I'd like a wide 13/14 to run some stretch, it's just not in the budget.
The wheels are 13x6 et13 so it should still look okay. Tire's should be flush.
Trying out a colour. Matches the engine block...
I've also started to prep the front end for paint. Doing it right this time and will be spraying everything from the firewall forward. After pulling the passenger side fender, I was reminded of how hack this car was previously put together
There was putty wedged between the rad support and where the fender sits and the expansion tank was held on by foam and electrical wire tied in knots... I'm going to delete the expansion tank for now but keep the mounts in case I need them in the future.
Started by scraping the big globs of sealant/coating off. I'll get hit the rest with a wire brush.
A buddy helped weld the new quick release spline to my steering column.
