Coming along great!
Satchealous Garage Mk1 rabbit
That's the plan. Charcoal/emissions stuff is removed, carbs will replace all the CIS bull shit, brake booster is removed and I'm running a vacuum advance saab distributor to delete the ignition control unit. Should be a fairly empty bay...gunna have to trim down a lot of wiring.Originally posted by softg View Postyou gonna clean up some of the plumbing while you're at it?
getting there!Originally posted by HooWybrow View PostHurry up and finish it.
That is all.
ThanksOriginally posted by Vito View PostSome serious Dedication to the rabbit, nice work man !!
Made my master cylinder adapter today so I can delete my brake booster. Running the stock booster bracket but with a plate welded on. Just have to shorten the pushrod now
Not too pretty but it'll work.
Thanks. The scirocco was a cool car. It was running an aba block and jh head so it had some nice compression to it. Not a ton of power but pretty peppy and a ton of fun to drive.Originally posted by superturbodiesel.com View Postthat's porn! Also can't wait to see how the scirocco will be finished.
my buddy ended up selling it for this though:
So I went out to grab a couple parts from a guy today and ended up coming back with these!
13x7 and 13x8 Revolutions in what looks like et0
The guy also threw in a ton of spacers and hardware
Fronts are on a 7mm spacer right now to clear the brakes.
Pokes a bit much right now. But by taking a couple mm out of the spacer, adding a touch of camber and maybe a fender pull, it won't look as crazy
Rears fit super minty
