I've done the math and it just doesn't seem 100% correct, i recently bought a set of 19" vskf's. The specs are 19x8 +38 (A) disk all around, now i read that the (A) disk faces are just standard, not maximum lip, nor maximum brake clearance... So I'm curious to see what i can possibly get out of these wheels, I'm going for 20x10 around +20, +30 offset with hopefully 3-5" lips, Step lip.
When i tried to do the math, i got 5" outer lips and 4" inner barrels coming out at 19x9 with a offset of 50.7... I'm probably way off, i desperately need some help!
However idk if stepping to 20" is going to change anything, and if step lips add any extra offset either, be easy on me I'm kinda new to building wheels. ((But i did some homework before i came crying for help!!))
Im not pressed with cutting or reusing the previous barrels, considering there welded together.
Ps: i used the equation
+1" lip/barrel = +12.7mm to previous offset
+.5" lip/barrel = +6.35mm to previous offset
-1" lip/barrel = -12.7mm to previous offset
-.5" lip/barrel = -6.35mm to previous offset
