may i have some clarifications on the part with the subdivisions please, thank u
OZ Futura lips nad barrels sizes.
are you sure, because the wheels are reverse mounted but i measure the barrel and it's over 18cm, which means 7inch...Originally posted by Zic View PostIf they are reverse mounted, they should be 1,75inch lip and 6,75inch barrel.
probably the barrel is around 19cm, as the lip sits just like this, the only one difference here is that the wheels are not sandwich:
1" lips .5" face and 6" barrel for 7.5" wheelChris Lane - fifteen52 - Join us on Facebook
chris@fifteen52.com 813.505.7910 - direct : 213.373.1552
RML | 52 Wheels | KW | ST | B&G | Newing-Alpil | C2 | Air-Lift
are those wheels sandwich mounted ? looks like alot of area on the center to fit the barrel behind the lip, with the center fitted in from behind. then the center would be more flush with the lip.
and as to what size a lip is, if it's .5 inch from the bead where the tire sits to the bolting surface, I call it a 1/2" lip. that is the conversion I used to identify lips before and it seems to be true.
best thing to do is take em apart and then measure them...they need a refinish anyway.
Instagram@jdjurhuus
