Didn't know about this toe thing. Thought it wouldn't affect this much.
Anyway, I'm running on Toyos Proxes4 for 8k miles, and they have pretty much rubber, yet.
The front ones are a little worse (went to the track twice), but I think they'll last until august/september
if your toe is at zero, then camber only affects how evenly the tires wear... after that, it depends on how much camber you are running and how stretched your tires are.
IF you're partly on the sidewall, then obviously the tires won't last long. At -7.9 camber and a 245/35 over an 18x11.5, I only expect to get ~2-3k miles tops out of the tires. Luckily, I haven't run on a set of wheels/tires for more than 1000 miles.
60-80 for an allignment by me. My fronts are going strong about 6 months with -3 camber and just a pinch of toe. Ill need to replace em in a month or so because of the inside wear, prolly add camber to make them last longer. That was a good set of used ones btw.
About a year ago I picked up 8 17's and 2 18's from a legit used tire guy and I am just running out now. The guy hooked it up for 10 a tire cause he thinks drifting is rad lol. Would have burned thru them quicker but my car lost a lot of running time last season then I swapped the wheels to my DD.
You know, it wasn't until I really started thinking about this that I realized that I usually use needing tires as an excuse to buy a new set of wheels.
Same here. My last 3 sets of wheels have been acquired because I needed new tires lol.
I'm not stanced but my POS tires have lasted me a good few thousand miles and are still at like 70% tread. I mean they would have more but I like to do burnouts.
The exception being that on my old A4, with about 7degrees of camber in the rear, I'd go through tires in about 10 thousand miles, IIRC. IDK, that has been a few years.
