1/5/2010
Well today I got the car off the ramps, moved it over a little and got the passenger side up on the ramps.
Decided to start on the rear light I will not be running.
Made a patch for the hole.
Got the patch cleaned up and was a perfect fit. So ready to weld.
All welded in a ground down to flat. Also filled the two little holes on each side of it.
Then got to the rocker and got one patch made and tacked in.
Tomorrow I just need to grind that down and make another little patch. Thankfully this rocker is no where near as bad as the drivers side. Hopefully later this week I can get started on the spare tire well.
