Project 02
  • Looks good! Sick work, I wish I was that patient.
    Originally posted by da3bous
    • wow. amazing work. with that much attention to detail with the gauges i can only imagine how the rest of the car will turn out. keep it up
      • making me want to sell my 240sx and put the dough into my 280z
        Its all about
        "Fit&Finish..."
        Originally posted by HooWybrow
        I gotta say, I saw this car, and got a boner.
        And, no, it wasn't just the pleat in the pants. It was a full fledged man-love-car boner.
        • 11/22/2009
          Today I cut out some of the bad rust spots.
          Cut out the bad section on the fender.
          Then went to work on the rockers.
          Hopefully I can get some of these parts welded back on later this week.
          • 11/22/2009 Part 2
            Cut some more rust out of the rocker.
            Then worked on the bad spot in the trunk.
            • nice build thread. i feel your pain with the polishing and the rust work. i spent over 600 hours doing all the alloy bits on my motor (there are a alot of bits, including the engine mounts too lol), and while stripping rust and paint with a wire wheel the other day i had bits of wire flying off it and one stuck right into my arm! sand looks like a much better option to me.
              keep up the good work, this is going to be sweet when finished.
              • Update time!!!!!!!!!!
                12/05/2009
                Well today I woke up and put my dad to work.
                Welded up the holes for the trim I am not using.
                More work tomorrow, hopefully we can get the drivers side done and maybe a little on the pass side.
                • Nice work. gauge cluster looks great.
                  • 12/06/2009
                    Started today welding some bolts on to the body so I could use the slide hammer on the dent.
                    A little better, I will have to use some filler though. Someone has tried pulling it before and the metal is a little weak, so it kinda popped back in.
                    Also did a little more work on the rocker, it still needs some grinding and welding but I ran out of wire for the welder.
                    • awesome work man!! keep it up
                      TastyGarage
                      06 xB
                      08 IStreefiddy
                      • Is that spot oilcanned? If you press on the back of the door does it pop out, then pop back in when you let the pressure off?
                        If so, and if you have a hammer and dolly, you need to bump on that door a little, hit square on the dolly in the low spots. This will stretch the metal and make it pop out permanently. This equals less filler which is the best thing to do. I had an oilcan on the E21. It works pretty well.
                        Also, (tell me if you know this stuff so I can shut up) you're not seam welding are you? Running a full bead? You need to stitch weld. Which means spot welds on the patch panel. Keep the heat off the sheet metal by moving around a bunch. This includes grinding as well! The heat makes metal shrink (which is where your dent in the door came from maybe).
                        Get my number from Mike and call if you need me to clarify. Doing a few things will save you a PILE of work in the long run.
                        Mr. Belvedere
                        • Originally posted by TheNeek View Post
                          Thanks for all the help. It should make all of this much easier.
                          • 1/2/2010.
                            After the last few weeks of being sick and being out of down, I got some work done. I had a late start but got the holes for the rear side marker filled. Hopefully Ill be able to knock out the rest of the drivers side tomorrow.
                            • 1/3/2010
                              Started today by welding in this patch into the front fenders rocker.
                              I had a couple of little holes I had trouble filling with weld so I made a tool. Copper pipe to hold behind the hole that I am filling.
                              Then got started on the last patch of this side.
                              Tacked the top in and then formed it to the curve of the rocker.
                              Then went back to all the patches and finished the welding on them, and filled(or tried to) some holes.
                              Still need to do a little more welding and then go back and grind it all back down smooth. Then light filler, prime, and some texture stone chip spray, I hope it comes out ok.
                              • 1/4/2010
                                Well today I pretty much finished off the drivers side rocker. I got fed up with filling in a group of holes so I just went ahead and cut out the bad section. Its all welded up and just needs a good going over before I lay some filler in. I will do the final clean up when it is ready its just way to cold for filler right now and I will probably do all the filling on the car at the same time. But anyway here are the pics of a (FINALLY) solid rocker.
                                Plans for tomorrow; get it off the ramps, move the car over a few feet, get the pass side up on the ramps. After that ill get to work on cutting out the patches for that side.
