if u decide to sell any of ur sets let me know.
Romans Daily/Drifter/Track Car
some work in progress shots
the LMs after disassembling
there was no clear coat under where the center mounted so all that black stuff is dirt and corrosion
this pic was after hitting it with a scotch pad
so i got out some 240grit and 600 grit paper and went to work on 1 area to see what it would come up like
here is the result after giving it a quick buff with a cloth
Last edited by 180roman; 08-20-2010, 09:15 AM.Drinking Enthusiast with a Car Problem
a couple of hrs of hard work
i decide to use the wheel with the most clear coat damage and 2 little bits of gutter rash, just in case i damage the clear coat more while sanding them
i also quickly reassembled the wheel centers in the position i would like to run them on the car with 4 bolts to hold them in place and measured the offset with a ruler, confirming that my calculations were correct, making them 9" +5 offset
here is the result
i really don't like the visible line between the clear coat and the part i sanded and quickly polished with a rag, so i think my only choice is to fully strip the clear coat and re polish the lips
there is also a slight 0.5mm step in the lip between the clear coat and the part i sanded, which i will also need to sand down when i get some more abrasive sandpaper, 100grit should doLast edited by 180roman; 08-20-2010, 09:16 AM.Drinking Enthusiast with a Car Problem
Well worth it dude, Uncoated alloy goes milky ater a while, the ccw's already have.. Im gonna get them polished in a while and hit with clear..Originally posted by anthLucky they didn't come into your house and disrespect your whole family.
i can't see picturesOriginally posted by 180roman View Posta couple of hrs of hard work
here is the result
other than that great work so far
in this post and the one before it
yeah i know i'll ask Laurence from WheelTech how much to just coat the lips
thats coz u got the Track model CCWs which are raw
oh also a little birdie/tracking number told me that my skid wheels are almost here
they arrived in Sydney on Thursday, which means they will be here on Monday
i've got something special in store for thoseDrinking Enthusiast with a Car Problem
Originally posted by 180roman View Postyeah i know i'll ask Laurence from WheelTech how much to just coat the lips
Which is Why I am not rushing to clear them haha.. To me they are just wheels.
Cant wait to see what you do with then next set haha.. You gonna run the lm's on the 26th? or rs?Originally posted by anthLucky they didn't come into your house and disrespect your whole family.
i'm hopping to be running LMs on the 26th
The RS's will probably end up going for a rebuild
i need to get one of the front barrels welded as it has a hairline crack and the outer lips have copped a bit of a hard time on the front
i had a tire pop off the bead while drifting and i ended up sliding sideways on lip
i once tapped a gutter with the front wheel sideways and i also got another dint recently from a potholeDrinking Enthusiast with a Car Problem
maybe not new
i'm thinking of running rear inner and outer barrels bolted to the front centers for some 17x9 +12 fitment
and for the rears it would be inner front barrels with rear centers and some new 1" wider(3" or 2.5") lips for some 17x9 -4 fitment
