I quickly decided i had to throw the new parts onto the more recent A4. The thing is, that this car, given its age, and mileage, would give me a hard time working on it, mostly due to the road grime and debris. All in all the car was in great shape, never seen and accident of any kind, that is why I bought it in the first place after looking for quite some time for the right one.
I will guide you through the process of the swap, which took about 12 hours, and did it all by myself. It needs patience, and some good quality beer and music. Other than that it is pretty straight forward if you have basic skills.
I started by removing the sideskirts first, then the front bumper, then wheels. front wheel arches, and front fenders, and then put everything back together - hopefully.
Driver Side sideskirt removal
First you remove this plastic to gain access to the bolts beneath it
Part 8 by mgpdoc, on Flickr
Many bolts that need to come off
Here is what you are left with, once you remove the sideskirt.
After some degreaser and a lot of time
Passenger side sideskirt before and after cleaning
Passenger Sideskirt off
Then we lift the car on the air to work on front bumper and fenders
Out came the bumper and the washer fluid
No going back now
Passenger side was definitely the hardest one to work on, more things in there.
Lower fender bolts gave me some trouble due to grime and corrosion not letting the torx bit sit in as it should. Then when it did, this happened.
Nothing some angle grinder cant fix though
Instead of this
To the left, the stock A4 fender - sideskirt support and to the right the Rs4 one which is wider
Installed in place
First fender was on
It was now time to see whether the fender line could at least be put in place although it is to be expected to be smaller than needed
Yeap, and smaller it was. However it fit in place, and nothing rubbed so it will do until i get the RS4 fender liners - if hopefully they are still in production, fingers crossed.
Headlight washer system was removed, I always found it useless and also it will interfere with the future IC setup.
Clean bumper ready to be installed
However I had to do something about this here which led to washer fluid leaking if not plugged.
At first i thought of doing another route or something.
But then I remembered i have some silicone hose plugs, which is a big win especially when you have them in stock and can also choose colour lol.
There, super clean, and neat
Bumper and Fenders were, on, time to put the remaining things back on
This is missing and is on order
Part 9 by mgpdoc, on Flickr
Time for the sideskirts which at the rear part were wider due to the rear fenders not being on yet.
Touching ground and as you can see the car got significantly wider
As for the rear bumper, I can install it in place, however, the side parts of the bumper stick out too much unless the fenders go in. Pics from my old test fit for reference
Some random pics of the car, that day
9 years between these two photos, in the same location
Part 11 by mgpdoc, on Flickr
Hope you liked this as much as I did.
Cheers
Mike
No going back now
Instead of this
Installed in place
First fender was on
Cheers
Mike
