Wilz e36 OEM+ sport build....with s54 on route
Few little bits to update....m3 evo clocks now fitted, just gotta get mileage to match my cars mileage and then plumb up the oil temp
New wash bottle arrived with new hardware
Old subframe is off and new subframe is all fitted. I have new tank straps coming and new caps for cradle bolts
All outside and finished, drives like a brand new car now, very firm
So plenty of updates...front axle has been finished with revshift mounts, condor lifters, solid bush on steering knuckle
Rocker cover powdercoated in crackle black, thermostat housing in crackle black, bonnet catches powdercoated in satin black
Rtd shifter is fitted now with new gaitor and nylon white knob, anodised black shaft
My s50 b32 Geoff steeling race engine has arrived with all sorts of goodies and crazy sp c motor
Got car fully striped ready for the transplant
Few pics of engine fitted
Secondary air start blanked
Evo coolant bottle bracket and throttle bracket powdercoated
Geoff steeling exhaust manifolds heat wrapped
This is original heat proofing, since has been removed
Billet oil filter housing goin on and billet exhaust mounts
Plenty more updates coming and a tonne of parts on order. I will try and keep updated as much as possible
So made a lot of progress since last updated this. Engine is in and running, not without a load of problems along the way.
So engine in , subframe on and solid steering bush on
After engine was in it went for tracking
Manifold fully wrapped and fresh studs
Here are some pics of it fully fitted and running. Upgraded all coolant hoses, upgraded under drive pulley kit
New renown steering wheel fitted with classic motorsport bump, and my rtd shifter. All togetha, driving this is a mega package, engine is mega, so so much power. Few more little bits to dial in but wil keep updated as I do them. Thanks for reading
this is so perfect !! noticed the good old novak coilovers you had on previously, i love the interior and that engine is a special bit of kit, whats the estimated power figures?LIL HIGH x LIL LOW
My stage 3 Focus ST MK2 build:
http://www.stanceworks.com/forums/sh...CON-1-Focus-ST
Geoff steeling racing Built engineOriginally posted by Nagah View PostWhat are the specs of that engine?
S50b32 e36 evo
CAA carbon plenum
Shrick 284's
Decked block
New oem Rods
New oem pistons
Balanced crank
ARP bolts
Iridium engineeringvanos kit
Motorsport cold stat
Viscous delete
Aircon delete
Kenlow 14" fan
Chip wizards ecu making 351hp on a basic map
I've spoken to Wayne personally an he reckons it's a base map, he guarantees seeing it again will make a genuine 375hp
Rrp £12,000.
