Saving a 1993 FD...400+whp, widebody, shaved bay, etc
  • #46
    Started mocking up and working on one of the wheel well holes.
    Mock up one
    Mock up two
    Made up three shapes after the third revision. Transferred pattern to metal and cut it all out. Sprayed self etching primer on to help prevent rust
    And this is where I stopped today. Have them all tacked in, just need to make another pass and grind down the crappy welds. Also need to weld together the three pieces in the middle. Hopefully I'll get that done tomorrow
    • #47
      Did some more work today. One side is almost finished and I started on the other side
      • #48
        Well I ordered a few pieces to help with the engine bay welding, so while I am waiting for those to arrive I decided to work on the motor a bit and finally get it on the engine stand.
        Started out by replacing the rear cover gasket and rear main seal, then put it on the stand and took the oil pan off.
        Cleaned up the windage tray and such since a friend and I took it off to check the bearings (they are all solid, no play thank god)
        Also cleaned out the oil pan and installed my improved racing baffle. All nice and pretty!
        Flipped the motor over and started getting some pieces off to clean up and paint
        Going to get a new water pump, clean up the block/heads, paint the valve covers, and replace the valve springs. Is it recommended to put the fuel rails/intake on after the motor is already in or before? Or does it matter?
        • #49
          Haven't updated in a while, but I have done a decent amount of work on the car lately. First off, I ran out of room for all of my tools so I picked up another toolbox locally for cheap
          I got around to cleaning up the rear end parts. May have gotten a bit carried away on the rear control arms...
          The rear subframe had a couple rust spots so I went ahead and put down a rough coat of POR15.
          I went to get the new rear diff ready to put in the car and found some interesting stuff in it...
          It's a KAAZ 1.5 way that the previous owner took out in perfect working order...I saw no gouged teeth or anything of that sort, so I came up with the reasoning that the tiny metal pieces were left over from the stock diff and the previous previous owner didn't clean out the diff well enough.
          After getting the diff cover back on I went to put the new seals I ordered into it...but they looked different than stock, so I just ordered some new new ones from Atkins Rotary that were the correct style. The metal version probably would have worked fine, but I didnt want to take a chance.
          • #50
            I worked on the engine bay a lot more. The progress pictures make it look a bit rough, but don't judge it by the progress! You have to wait until it's actually finished lol.
            I received some advice in regards to filling in the pinholes from welding (which sucks the big wiener by the way, never doing another engine bay with a flux core welder...too easy to burn through thin metal). They suggested using jb weld so I went ahead and used it over all of the seams. I also put some on to flatten out the part where the headlight bolts onto, as it was already warped beforehand and welding it didnt help that issue. I figure jbweld is better than filler on that part.
            • #51
              One of my last big purchases arrived the other day! Went with Ksport for the air struts. I figure that if they do happen to blow down the road, I will just have FEAL rebuild/revalve them and move on. Everything I read gave great reviews of their air struts though, so I'm not too worried.
              Next big thing-started stitch welding the engine bay!
              Everything will be getting a coating of filler to smooth out the seams, so I went ahead and ground down the welds a bit too so it would sit flat.
              And part of that filler will be Rage Extreme. I read good reviews on it and quite a few people use it on their engine bays, so figured I would give it a shot. Hopefully it works well because it sure wasn't cheap! I'll be using FiberTech on the seams and this as a finisher
              I forgot to mention that when I put the rear diff/axles in the passenger axle seemed like it went in a bit stiff (my first mistake here...live and learn). Anyhow, it sat in further than the driver side and that bothered me so I tried pulling it back out to see why it sat further in. Anndd that's where things got complicated. The damn thing WOULD NOT come out. It took a big fat chisel and a large crescent wrench to pry that thing back out...and here is why
              Stupid clip decided to be a little hoe and get snagged in the diff. Messed up the threads on the shaft a little, but the diff appears to be fine. I guess the clip I used was a little too large (although it was the same size as the stock one). Also, I did install it the correct way up. I used a magnet to get out the metal pieces from the clip, cleaned up the shaft, put on a new clip, and put it back in the diff. Done deal. More updates to come once I get pictures
              • #52
                Got the covers for the strut towers made up this week. It's a good feeling to see it coming together! The only issue I have now is how I will seal underneath the covers. I sprayed self etching primer and weld through primer onto both pieces before welding, but I still feel like it needs something else in there. I was thinking of drilling a hole in the top and using a syringe to put POR15 inside, then use my air hose to spray in the hole and hopefully spread it out...but idk if that would work. Worth a try though unless someone has some suggestions. Anyhow, on to the pictures!
                Started by tacking it into place, working my way around and hammering it down to fit flush
                All tacked up
                Put the strut bar back into place before I welded it all around. I took my time doing 1" beads and letting the metal cool in between, but I wanted to be sure the strut towers wouldn't move with the heating and cooling
                Sanded down and almost ready for filler
                Same process on the other side
                Gotta be safe!
                It's coming together Finished up the bottom cover on one side
                I still have to sand down the welds on one side and figure out how to seal underneath the covers. From there I will fill in some more holes behind the strut towers and move on to the firewall. I'll have to drop the motor in so I modify the firewall enough to clear my intake, so while I have it in I will go ahead and run my wiring as well since I dont plan to use the factory spot.
                • #53
                  So it's basically the same thing going on. Still working on the engine bay and such with some other stuff mixed in occasionally. I wanted to see if I needed the side bumper/fender brackets so I mocked up the front bumper/fenders onto the car
                  It looks like my plan will work. I will have a frame mounted splitter that will hold up the bumper (while doubling as a splitter of course) and do away with the side brackets since they are mangled from a previous hit or two. Ill be using this PVC material from Home Depot to make the front splitter and the side skirt extensions. Only cost $75 for a 4x8 piece that is 1/2 inch thick. The full splitter sheet (74x30) weighs 24 pounds, but I will be cutting that weight in half most likely since Ill be integrating it with my Shine undertray. The splitter will only go back far enough to properly mount to the frame, then the undertray will extend from the splitter back to the subframe...if that makes sense. Anyhow, pictures of materials
                  Engine bay is slowly getting more complete
                  Started working on the wheel wells since the welds fried off the paint due to the heat. I'm going to apply self etching primer over the bare metal and seams, then scuff, then regular primer, then seam sealer, and then underbody spray over the whole thing.
                  This pissed me off...
                  I was breaking a bolt loose on the rear caliper and the reservoir fell off of my table. Broke the bracket and nipple off of the reservoir. Sweet. They only cost 200-300 for new ones. Ill see if I can find someone to tig the bracket back on and if not Ill just use jbweld. As for the nipple, my plan is to drill out the hole a bit and insert this metal fitting and then epoxy around that. I think that would be far more solid than just epoxying the nipple back on. At least with the metal part being inside the reservoir if the epoxy breaks loose I won't dump power steering fluid everywhere
                  And lastly, I got my J-Auto toe links in along with my power steering rack bushings.
                  • #54
                    Motor is in!
                    Sike. Not really I went ahead and mounted up the motor so I could modify the firewall as needed. Decided to try out the strut bar while I had it in
                    Good news is it fits with some cutting! Pretty excited about that. I'm going to have a plate made to go over the area I cut out to reinforce it again. Not much material left to prevent flex, but I believe a plate on top will solve that issue. Either way, it was worth it. I'll make a small cover to seal the bar back up so water and such doesn't get in there
                    On to the firewall modding. I just did a small section at a time to prevent it from splitting up too much. It was still a pain though. I don't see how anyone could do this cleanly without using filler afterwards to smooth it back out. Good thing I'll have filler all over my engine bay anyhow
                    I made sure there would be plenty of clearance all the way across so I can run various intakes if I so choose. I was going to eliminate the lip all the way across, but after doing this one section I think I will just leave it as is. I feel like the factory seam is more solid than the section I cut out and welded, so I don't want to mess up the structural integrity of the firewall more than I already did. The section I did may be more sturdy, idk, but I dont want to take a chance at this point. Ill be making a plate for the strut bar that covers up the sides so you wont see that area anyhow.
                    (See white paper. There will be a cover there and directly to the left of that on both sides)
                    • #55
                      My rear strut bar arrived the other day. Ill be mounting my air tank on the top bar and the compressors in the center...or the battery, I'm not positive yet. The tank will for sure be on the top though...no seeing out the back window ftw
                      Worked on the wheel wells some more. I needed to get them coated so I can put all of the suspension back in and start routing the air and brake lines
                      Self etching primer after cleaning
                      Then regular primer
                      Then seam sealer (I used a lot lol) and paint over the areas I didnt want undercoating
                      And finally the undercoating
                      This is how the car sits as of now. Hopefully going to prime the engine bay this week and start laying down the filler. Also going to get the interior completely stripped and ready for the sound deadener to be sprayed.
                      Oh! And the eastwood frame coating stuff worked great. I did the rails and underneath everywhere I welded
                      • #56
                        So it fiinnnaaalllyyy happened. I primered the engine bay! It was my first time shooting paint with a gun and it was actually pretty awesome. So much better than a spray can. I used eastwood epoxy primer
                        Prep work (ie cleaned up around the car and used prep clean on the bay)
                        Sprayed! Just one coat for now. I wanted to get some primer in all of the cracks and such for when I lay down the filler in the seams. Found this little guy after paint -_- Not cool. Oh well, I sanded around it and welded it up (rather terribly I might add, I really need a mig welder and practice...in my defense though, the metal there is very thin and is some sort of weird double layer)
                        ^This is right below the clutch master cylinder. I'm not really sure how that even happens, but oh well. Fixed now
                        So something that really annoys me and that I will get to in a bit is this. Some previous owner decided it would be good to be a caveman and used a drill/pliers to pry back the metal very crudely to get at a nut that broke off (one of the ones where the subframe brace and hpp 2in1 bolts up to) I'll probably use a hole saw over the area to clean it up a bit looks wise and to provide easy access for if the other nut comes loose
                        Interior is stripped and almost ready for sound deadening. Have to go through and clean everything still
                        First coat of filler. I used Fibertech to fill all seams and deepish imperfections
                        Then sanded it all down
                        And then a layer of Rage Extreme for the smoothing layer. Laid it on about 1/16" thick to make sure I have enough to make it smooth with one layer
                        Oh, and I decided to go ahead and add the height sensors to my air management now. Figure I should go ahead and run the wiring/drill the holes while the car is apart
                        • #57
                          Been busy working on the car and getting into yet another hobby (golfing..I played in high school and some in college and enjoyed it. Needed something to do in the summer so decided to get back into it)
                          Here are the new clubs for anyone that also golfs! Wife got me the driver (2015 Taylormade R15) and I recently picked up some Wilson D100 Hybrid/Iron clubs since my old set was old and an off brand. First time using them I improved my handicap by 10
                          And now car stuff time. Here is the progress on the bay
                          Sanding behind the strut towers is a huge pain in the ass, but it's coming along. Laid down seam sealer in the cracks behind there since I feel it would flex quite a bit and the fiberglass filler wouldnt work. I was comfortable using it elsewhere since I welded those seams, these aren't welded though
                          I've gone back and forth a thousand times on what power steering setup I want to go with. Plan was the mr2 setup (obviously, since I spent the money on it), but now I'm not so sure. While I make up my mind I figured I would just run the depowered fc rack that came with the car, so I cleaned it up and painted it
                          Well it turns out I didnt take pictures of it finished lol. But it's just black. I ordered poly fc bushings to use with the rack, but it turns out the fc rack sits lower than the fd rack using the stock bushings. So I made a spacer from a cut up sway bar bushing so the fd bushings would work. Worked like a charm! Except I accidentally drilled my hand. Fail
                          So...I changed my mind again on widebody. Ordered the feed style front and rear fenders. Plan is to modify my sanai side skirts to work with them. Here is a quick shop I did using the Dynotorque car
                          • #58
                            Top work man, coming along nicely
                            • #59
                              why haven't i clicked on this build earlier. fuck this is a great build thread.
                              top notch work dude, loving all the work that's going into this.
                              can't wait so see this thing all back together again
                              i shouldn't be daily driving this:
                              "Volkswagen Golf mk1 build thread"
                              • #60
                                Thanks!
                                Thanks man, me either!
