Body off! Engine crane worked well, apologies for poor quality pic, chassis was a lot of hassle to free off, and nearly every bolt had to be cut off. I even had to cut the rear valence away to allow it to lift off, tried lifting from front and sliding rearwards but just couldn’t get it off.
Engine trial fitted to see if it fits? no surprise it doesn’t……
Oil filter hits the chassis I know you can buy remote oil filters, but I may just notch the chassis to make clearance.
Gearbox also clashes with the chassis
Would have been nice if the gearbox fitted, but hey ho just a bit more work.
For the gearbox will just have to section or move out that part of the chassis and make it wider.
A little update on progress…………
Removed the power steering pump and a/c, and slid the engine forward so the gearbox clears the chassis, this still does not work out as the front of the engine is too wide to in the towers. It is also too high at the front.
The best solution is to get it fitting the best at the front and to section the chassis to make the gearbox fit at the rear. Engine mount locations work out nice and easy.
