Sedes body dropped w114
    With the stock brackets the alternator would of stuck through the hood so I had to make new brackets to drop it
      I had to make a bracket to move the power steering pump up and closer to the water pump so it wouldn't hit the steering box ( crap like this is real time consuming)
      • Originally posted by Jimfred View Post
        [ATTACH]10663[/ATTACH]
        Time consuming, and amazing. Your Fab skills are truly impressive, thank you for sharing your work with us,
        • Very awesome build. Not that you needed our approval...but you have it in spades!
          • Wow, amazing fabrication skills and love how much wheel your tucking in the back. Keep it up, and can't wait for more updates!
            http://cdn.stanceworks.com/forums/sh...ad.php?t=17224
            • Originally posted by KnotSewLo View Post
              Thanks for the compliments
                I stole some parts from my neverending blazer project
                • Jesus Christ. There are build threads, and then there are BUILD threads. Amazing work man.
                  Ol Dirty Bastard - RIP
                  Photo by Alex Dooley
                  2016 Ducati Scrambler, 2015 Subaru Impreza
                  • Thanks
                      The next issue is the engine hits the hood and Its as low as it can go,the oil pan is a half an inch off the ground when laid out
                      • So started cutting her up again,
                        [ATTACH]10766[/ATTACH]
                        and after lifting the back up 3" it gave me 1.5" above the carburetor
                        [ATTACH]10767[/ATTACH]
                        [ATTACH]10768[/ATTACH]
                        • I'm starting to put it back together
                          [ATTACH]10769[/ATTACH]
                          Pretty rough looking
                          [ATTACH]10770[/ATTACH]
                          Right now its function but funky,I'll play with it some more
                          [ATTACH]10771[/ATTACH]
                          • ahahah thats a dead giveaway to whats going on under the hood. I like it.
                            Ruining cars since 2006 yo
                            • I put a bill on the back so it wasnt so blunt,kinda like a cowl induction IMG_4131 (350x263).jpg
                              • I picked up a surge tank from jegs
                                [ATTACH]10861[/ATTACH]
                                Since the motor is higher than the frame I had to mount the surge tank higher than the motor water outlet to ensure the motor always had water
                                [ATTACH]10864[/ATTACH]
                                and i welded a drain cock to the top of the radiator so i can bleed out the air and also put a vent on the highest point of the engine to bleed air from it and return it to the surge tank
                                [ATTACH]10865[/ATTACH]
