Sedes body dropped w114
  • #76
    Pushed in and out of the way
    • #77
      After I got the body back on the frame I made front core support mounts,lined up fenders and hood and pushed it outside to get a first look at it all together
      MOST OF YOU KIDS WITH ADD SHOULD PROBABLY STOP HERE BECAUSE FROM HERE IT GETS REALLY BORING
      • #78
        not gonna lie, ive been looking at every single update and didnt think it was going to be very promising...but you have changed my mind. damn good job sir!
        Originally posted by BozoBubble
        Stance bug bites hard, man, you ain't gonna shake it.
        Truck Build
        Instagram: somestancekid
        • #79
          Thanks
          • #80
            Originally posted by Meeve View Post
            this is serious work. Nice work so far! I can't wait to see where this is going. It will have so much stanceeee so much tuck oh yes
            Thanks
            • #81
              this is ridiculous. i <3 it
              instagram: @keenanhaye
              • #82
                You're a pretty fucking awesome dad!
                Great work
                • #83
                  Great work
                  Thanks for the compliment
                  You say awesome-I say idiot
                  • #84
                    I used the wiper motor from the S10 which also gave me intermittent wiper
                    • #85
                      This was one of the biggest pain in the ass things-
                      I used the steering column from the S10 because everything bolted in and has tilt also thought it would be easier because the wiper switch,dimmer,hazard and ignition switch were all on it-BUT most newer columns use smaller gauge wire with external relays and the ignition switch was wired to to CPU with and anti theft-but mad props to the S10 forum for all the wiring schematics-
                      The other pile of wires you see is a universal wiring harness from Speedway Motors that was a piece of cake after figuring out that column
                      Hindsight 20/20 I would have used an older colomn
                      • #86
                        I would think something like making the lights work would be simple once you have power to them but the awesome German engineering from 1972 didn't survive
                        The tail lights have a printed circuit board that was shorted out and brittle so there was a lot of soldering and epoxy,I should have drilled holes in the backs and snapped in some universal bulb sockets or used LED strips,the fronts weren't as bad except for the outside lens already being broke,2 of the side indicator light backs were broke and missing so I epoxied some universal sockets on them
                        • #87
                          I made this shity looking box to hold a shifter a got from a 65 mustang (I had to put at least 1 ford part on it so whatever breaks I have something to blame it on)
                          • #88
                            I used a master cylinder from a Monza because it had the right size bore to work with the stock proportion valve and brakes,I also drilled the brake pedal lever up higher for more leverage since I removed the power booster
                            • #89
                              I shorted the seats so his head wouldn't hit the roof-I thought they came out pretty cool
                              • #90
                                Ya!! man dude it's awesome how ambitious you are and it's great to see another truck on Stance Works
                                Website: http://cougarhousegarage.com/
                                Check Out Our Facebook Page For More Pics and Videos
