Day 2 is done. Making good progress. Not working at a break neck speed lol. drill battery died, seized bushing then I got some PB Blaster in my eyes. That was the sign to call it a night. Anyways, here are a couple teaser shots for the time being to hold everyone over for a couple more days.
Looking forward to the updates after the install. Ive never seen that front bag before. If it bolts on the the Uvair one then the ground control plates should work. I use them with my setup.
my front air struts showed up today (I'll post pics tonite after work). I scored my self a garage with lift for the entire 3 day weekend. So tonite and the following nights Im going to be reading and going over everything again to be as prepared as possible for the install. Haven't read through the AccuAir lit since the day it came in, so i refresher will be nice. From the looks of everything, my GC camber plates will probably be useless. No big deal. It looks like I have everything I need though. One last run through my parts inventory. there might be some building going on in here yet lol
Them brackets not going to do you any good. I have some sitting here at my place because there was no way to fit them. Best way to fit them rear bags is to cut off both "bumps" weld a stud up top to screw the bag into. Then drill a hole down the center of the bump on the trailing arm so you can get a bolt up into the bag. On the side of the frame up top. Cut out that half moon so you can get your fitting in for your air line. Bam done deal.
I mean you can try it. But I did for a few hours and couldnt come up with anything. If you do, then please share.
