I love the build. I had seen the pictures you posted in The e21legion, but I'm glad I fo jd the thread.
e21 BMW 316
This thing is absolutely mint mate
Crazy nice car man! Didn't think I'd like the blue, but it turned out more than perfect.1991 BMW E30 325i Touring
Looks like all the hard work is paying off
As my speedo (on the e21) is reading low, I looked online and bought myself a digital heads-up display that uses GPS. It was only £15 and just puts your speed in your line of sight. You can even switch between MPH and KPH, or set an audible alarm for when/if you reach specific speeds.
Under power, the lower steering UJ is touching the exhaust manifold ever so slightly. I also want to remove the rubber coupling, as the heat from the manifold makes it soft and allows too much play I think? It's not a huge problem but just teething troubles really. I've got a smaller bore brake master cylinder now, which I want to clean up, paint and rebuild prior to fitting. I also intend re-drilling the brake pedal to alter the fulcrum point and decrease pedal effort.
Eventually I intend fitting throttle bodies but till then, I want to shield the air filter from engine bay heat. I was thinking along the lines of an aluminium box or something, that could simply be mounted on the inner wing? I may have to indulge in some CAD. (cardboard aided design)
Hopefully today will be dry and bright, as tomorrow Retro Car Magazine are doing a photo shoot.
I was chuffed to see the E30 make a few nice pics from RRG15.
Few random pics.
