E39 Build: 6.0 LS. Coils. Burnouts.
  • #76
    Do you have to contact information of the guy that fixes the pixels in the cluster?
    • #77
      Just read the whole thread, and you win the internet. Very nice build.and congrats on the powahhh!
      • #78
        I read this thing so long ago...glad to have found it again. Epic thread and car sir. You make me want to LS swap my LS400 hahaha
        • #79
          He had a deal going on for half off, but the promotion ended.
          2001 BMW 560i 6.0 LSx/T56 SOLD
          2000 Corvette Hardtop FRC
          • #80
            Oh deer
            Poor guy sprinted into the side of the car while I was doing about 50, don't think he made it. Needs a mirror, fender, possibly some small dents removed from the door. We can rebuild him - we have the technology. It just sucks that I literally finished all the bodywork a month or so ago (new paint on fenders, hood)
            • #81
              Folks...this is not a drill...hold on to your drinks....we have gone completely legit
              At the local oil change shop.
              Ironically all they could find was a burned out rear plate bulb (which they couldn't figure out how to change, LOL).
              So, that's a big relief to have that out of the way.
              As usual, fuel consumption is very frugal - much better than all those pesky "other" hybrids
              Just kidding, wish those trip computers worked.
              I calculated economy after a long trip recently:
              15 mpg city beating the piss out of it
              23 highway beating the piss out of it (cruising @ 80, a few triple digit blasts)
              • #82
                So basically you get 15/23 driving it normally.
                That sounds par for the course.
                Originally posted by Ollie
                • #83
                  I wonder what kind of economy I get doing burnouts
                  BTW I have more go-fast goodies lined up. Steeper gears and lower profile tires for overall shorter gearing. It is shocking how much a tall sidewall tire kills the fun factor.
                  • #84
                    GO-FAST GOODIES! love this car. keep it up.
                    E36 Bonnie
                    • #85
                      Such a thorough build. Love it man.
                      • #86
                        ohmyjesus. This is quite possibly the best thing on the interwebs.
                        • #87
                          I was getting tired of the "tall" gearing (even with the 3.62 M3 ring and pinion) so I decided to pull it all apart for a gear swap. The 3.62 is the shortest ratio that seems to be "readily available" in production cars - it seems that the 3.91 and 4.10 ratios in 210mm size are "Motorsport only". 4.10 was my first choice, but seeing the price tag made my head spin. Luckily, the 3.91 was offered for a few years in the E34 M5 (which is still absurdly rare). I got in contact with a guy who had his turbo E30 (with a 210mm rear swap) set up for drag racing that wanted a taller ratio, so we worked out a deal to swap ratios.
                          The older style 210mm ring gears use M12 bolts, while my E39 M5 center LSD carrier has thru holes for a 14mm. I had the option of ordering bolt sleeves through a BMW Diff shop but decided to get some experience in machining.
                          I ordered up some Tool Steel rod with a .5781" OD which gave me a nice press fit into the carrier, but had no thru-hole.
                          Carrier holes with chamfer
                          It took me a while on the lathe but I got a rhythm going and banged out a qty of 10. The thru hole was relatively large in comparison to the OD so I had to step up the drill size 3 times for each part. Very repetitive but fun.
                          I didn't want to reuse ring gear bolts with an unknown history so I ordered up some ARPs. Sleeve fit perfectly for the ID
                          Tapped in the spacers using a brass block and hammer to avoid damage
                          Threw on the ring gear and tapped it down using a rubber mallet. It's a very tight fit as you get to the bottom of the carrier flange and there is no room for rotation so you have to get it aligned with the thru holes correctly the first time. I was able to get it right on the first try. Like they always do, ARP included washers with their hardware and I wasn't sure whether or not to use them since the OEM bolts are flanged and don't use washers. After measuring the depth of the threaded ring gear bolt hole I found that I still had tons of depth to go even without a washer and decided to leave them out. Some red Loctite and 110 ft-lb torque gets me this:
                          I also replaced the front and rear pinion bearings and races while I was in there. Bought a HF 12 ton press and was able to bang it all out myself. The pinion probably didn't need this following step but I wanted to use our basement freezer, damnit.
                          Dropped the diff off to be set up at a shop last week, hoping to have it back in the car in the next few days.
                          • #88
                            I found some old pictures from a few months back that I took after I got the fenders rolled in the rear. I use this build thread as a record of sorts and i realized that I never took pictures of the exterior after the M bumper conversion (front and rear). I am not a fan of the stance movement (quite the opposite - stick your stretched tires up your ass) but I do like things to look proportional to the body. Up front: 225/45/18 with a 12mm spacer, and 235/50/18 rear with 10mm spacer. Those rear tires are since gone, replaced with 245/40/18. I never really plan out tire size when replacing- just whatever is readily available in something close to my size, and cheap (with the way I go through tires it makes sense for me).
                            • #89
                              was out at Bimmerfest East a few weeks ago. a guy on bimmerforums snapped these:
                              • #90
                                Fabulous build keep it up
                                Mx73 Cressida Build check it out!
                                http://www.stanceworks.com/forums/sh...ad.php?t=59875
                                Ig: Japetto516
