Spent some time in the garage last night. The hose bib fitting was leaking so that came out for a new one to be sweated in - of course I ran out of half inch copper pipe couplings, so that will get done tonight.
Onto the automotive work - it was a drivetrain kind of night
Sprayed down the subframe a bit with brake cleaner, then simple green, then finally warm soapy water to clean it up.
I had drained the diff a few weeks back when I pulled it out of the car, so I filled the diff with about a quart of new Mobil 1 75W-140, and turned the output stubs quite a few times to churn up all the sediment/beer can tabs in there, and drained it. When I had the cover off I cleaned it up fairly well inside and resealed the cover, so it was nice to see only a bit of brown that came out. Filled it back up fully, torqued the plugs, done. I would have reinstalled it in the subframe last night but unfortunately my new front diff bushing melted/deformed just enough during the mount reinforcement welding that it was junk - slid out of the bore with a strong push from my fingers - so another is on order. I should have waited to install it until he had done the welding with the old one in place, so the blame is on me - but live and learn.
I also took apart the shifter on the T56 to diagnose and solve a somewhat severe rattle I had under load. The plan was to replace what I thought was a bad receiver bushing (plastic) on the shift rail. Of course I found that it had been replaced with a brass one when I had the unit rebuilt last year. The shifter itself felt funny and loose, so I disassembled that and found the aluminum cast case to be cracked in a few placed with some small bits of material missing around the central ball fitting. Keep in mind that I bought this used with unknown miles and proceeded to beat the hell out of it for 10,000 miles, so I really owe it nothing. I was never really satisfied with the shift action of the stock unit so I decided to treat myself, and picked one of these up
MGW
With all my bodywork now at the painter's I placed an order for a few things that I wanted ready when he was done so that I would not be held up, as well as some other items that I have been putting off.
Fender Liner hardware
Fender bolts (OEM Torx)
Angel eye harness - one side of the current setup is fraying/damaged and causes flickering
Axle to diff stub hardware (OEM external Torx) - with as many times as I've removed and reinstalled diffs the external torx heads on these are torn up.
Front diff bushing
Rear sway bar bushing brackets (steel) - factory material is aluminum and is prone to failure. The steel units are from an E36 M3 application
New cabin air filters- Mann
I have a lot of pictures of recent progress and details somewhere but my laptop has been acting up lately so I am in the process of backing it all up onto my HDD.
MGW
Front diff bushing
