6th Gen Accord Coupe Build
  • #76
    Originally posted by MommysLittleMonster View Post
    Radical build, really excited to see where you go from here.
    Your car is very well put together, I like all of the design choices you've made thus far. I have a huge appreciation for tidy, well thought out Honda builds.
    Thanks man!!! I've loved you're Prelude build. Still have it? Love those 5th Gens and that green. Big fan of the M3 build also.
    Sent from my iPhone using Tapatalk
    My Accord Build
    Instagram: @puzzlemaster94
    • #77
      Originally posted by puzzlemaster94 View Post
      Thanks man. I'm trying
      You know Jordan too? Yea, I wanted the Rotiforms he had on his RSX, but he sold them before I had the chance. I did buy the tires off him though. Yea, I've hung out with him a few times and bought parts off him. Post some pictures of your sedan. I've really wanted to do a sedan build, as I can swap most of my parts that I'm not using on the coupe to a sedan.
      Yes I do! That's the homie we've been friends for years now. My sedan is wrecked right now so it's just sitting.
      Names rob from northeast ohio(Youngstown).My car is a 2000 Honda Accord sedan 2.3L VTEC 5 speed. 285k on the clock. Had this car for 3 going on 4 years. Used to be my moms car then I wrecked my 5th gen accord :(. After that my dad bought her a van and passed this down to me being I had no car...
      That was my build thread for it. I'm currently working on a ford probe gt right now but will tend to the accord when I'm done with the probe.
      • #78
        Yea, Ive seen that thread. Probably commented in it too lol. Shaun on here has a 2G probe bagged on VS-KF's, but I'm sure that you've seen that already.
        Another friend of mine has a 2G Probe also, but it has the JDM KL-ZE in it. Pretty fun car while it was running around.
        Also ordered what I hope to be the last remaining parts for this swap. Also debating on machining up some 3/8 OR 1/2 inch spacers for the motor mounts to raise the motor just a bit, since the J32 oil pan hangs down 5/8's of an inch more, compared to my J30. I should have the added romm, since I replaced the J32 manifold with a J37 manifold
        My Accord Build
        • #79
          Did some work on the J32 today and drove it to a show.
          Accord and Skyline by Evan Aschbacher, on Flickr
          004 by Evan Aschbacher, on Flickr
          001 by Evan Aschbacher, on Flickr
          Accord 3 by Evan Aschbacher, on Flickr
          My Accord Build
          • #80
            Well it's been a while again.
            Grabbed some BC's and went lower, bought side skirts and a rear lip, installed my roof spoiler, and a few other odds and ends. Here's how it sits before I get the front camber I need for clearance in the front.
            IMG_1974 by Evan Aschbacher, on Flickr
            Accord 15th Street by Evan Aschbacher, on Flickr
            My Accord Build
            • #81
              Here I am again not posting progress.
              First off, J32 6speed swap is done. If you are interested in the breakdown of the parts, here it is:
              Engine:
              J32a2 out of a 02 Acura CL Type S Auto
              --Around 80k on the motor
              Parts to Convert it to a Manual Engine:
              --Manual CL Type S Engine Harness
              --Manual CL Type S Front Cam Gear
              --Manual CL Type S Front Cam Gear Plate
              ----Reason for this, the manual motors use two cam sensors, auto only uses one.
              --Manual CL Type S Crankshaft Gear
              --Manual CL Type S Crankshaft Sensor
              --Manual CL Type S Crankshaft Sensor Sub-Harness
              ----Reason for this, the automatic sensor will not work with the new gear or plug into the manual engine harness. Also the manual sensor is just a plug and harness, while is the auto is all connected.
              J37 Intake Manifold Upgrade
              --J35 Top Plate (Says Honda instead of Acura and has no butterfly valve plate)
              --P2R Throttle Body Adapter for J32a2 Throttle Body
              --J32a2 Throttle Body
              Innovative 60A Engine Mounts
              CL Type S Manual Flywheel
              P2R EGR Block off Plate
              ECU:
              Manual CL Type S ECU
              Manual CL Type S Dash Harness Plug mated to Accord dash harness
              --This connector is called Connector "E" on the CL Type S
              --Accord dash harness Connector "A" is what you want to wire it to (one that goes into the stock ECU)
              Transmission:
              2003 V6 6Speed Accord Transmission
              --80k miles
              7th Gen Accord Shifter
              CL Type S shifter cables
              CL Type S Shift Cables Stay
              2003 Accord V6 Manual Starter
              Manual CL Type S Shift Boot
              03 CL Type S Transmission Mounts
              03 CL Type S Master Cylinder
              03 CL Type S Slave Cylinder
              98-02 Accord Pedals
              Exedy Accord V6 6Speed Clutch Kit
              CL Type S Manual Trans Crossmember
              Stock V6 Automatic Axles
              Miscellanous Other Parts:
              CL Type S Manual Fusebox
              Maintenance:
              Timing Belt
              Water Pump
              Front Main Seal
              Rear Main Seal
              Axle Seals
              Intake Manifold Gasket
              Exhaust Manifold Gaskets
              Throttle Body Gasket
              Timing Belt Tensioners
              Spark Plugs
              Parts Not Being Used:
              CL Type S Auto Engine Harness
              CL Type S Manual Dash Harness
              J32a2 Intake Manifold
              Auto J32a2 Front Cam Gear
              --This has smaller surface areas than the manual gear, so the manual sensor will not read it correctly.
              Other than that, here is a few more pictures. I'll try to keep this forum updated with the others as well.
              IMG_2441 by Evan Aschbacher, on Flickr
              IMG_2385 by Evan Aschbacher, on Flickr
              IMG_2369 by Evan Aschbacher, on Flickr
              My Accord Build
