Looking very cool bro.
W201 v.2.0
Originally posted by herrakani View PostLooking very cool bro.
Final version of brakelines.. this is 2nd version overall, i like how they are now, and best of all both front lines are 1 piece lines.
Originally posted by herrakani View PostYou don't run a linelock?Last edited by Exami; 03-26-2015, 02:53 PM.
Rear brakeline..
Mockup.
DONE!
Other than that it was crap of a day..
came to garage it was like this:
but driveable on big roads..
when i was leaving ...
So ~10 to 15cm of snow.. so i had to take be bmw on the back to get home.. and what was nice it has 3.0 turbo diesel engine and 4wd and winter tyres.. but the issue it wont blow any hot / warm air at all!!! so heater control valve stuck propably. or something like that.. was a cold ride home.. altho i got home safely.
difficult choice
hot and sketchy
or cold and safeFloccinaucinihilipilification
Originally posted by herrakani View PostSeems to depend much on the spot you are, literally no snow on Lauttasaari when I left work but 10cm at home. Disgusting. I still got some work left on my dd before I can start grinding the M5.
Originally posted by P78 View Postdifficult choice
hot and sketchy
or cold and safebut i foundout today the issue its the "heater control valve" or what controls it. once i unplug that... heat.. so works for now.
Moving slowly forward...
Can interface.
Display, will fit quite ok on the stock cluster
And rear brakelines:
Next up brake hoses and im pretty much done with the brakes. in couple days i will get fuel lines 10mm RST Pipe, some new bits for the rear diff, so going to redo that soon.
Things going forwards and backwards all the same time..
First off when i popped the oilpan out, this fella came out..
... about 2seconds later ...
No worries its only oilpump...
New fuel lines in da garage:
2x 4m of 10mmx1mm Stainless pipe.
Front brake caliper dont fit...
New rear subframe... soon time to modify
Also paintshop has been asking for the car so maybe soon that as well
Its not done yet!
Been working with the rear subframe.. (jig almost done)
Fuel returnline 10x1mm pipe
Bits has happened since last update: just let the photos show..
Brakelines:
Subframe stuffs
Fuel line stuffs:
Great work so far!
