On to the oil separator......
With the shop extra busy I was lucky if I got to work on the car once a month. This gave me plenty of time to research.
I decided that the OEM cyclone oil separator was so specific to plug into the side of the OBD2 intake manifold that it was a waste of time to try and use it. It would look terrible and a be a constant failure point.
Did a ton of looking around. Mann Provent 200 seemed a little overkill. My engine was low mileage, I am only running 12 psi and its size was massive. I saw that they were releasing a few smaller versions but know one in the US could get me one and the way they had to be mounted was going to cause some issues as well.
I called a few friends and got both a BSH and a 42 Draft Design catch can. My 2 problems were there size and they were more designed to be manually drained. I wanted the breather/ oil separator system to be maintenance free so both of those options were not off the table. I knew I could chop them up and make one of them work but I knew I could find something better.
As luck would have it around this time I started a large build on a customers E39 M5. The car ran 2 oil separators. Small compact simple design, an OEM design and they didn't have any check valves. My only concern was there lack of size. The factory used 2 on the 5 liter M5 engine so I wasn't sure how a single unit would would on a boosted 3.2 liter.
Regardless, I proceeded and developed this.
It uses the stock fitting on the valve cover, Pulls vacuum of the intake tube of the supercharger and drains into the dipstick tube. It was exactly what I wanted. A completely separate breather/ oil separator system with no maintenance. It was based on all proven OEM parts and fit completely hidden under the intake manifold.
