Beauty rings look beautiful.
1966 Volvo 122
This topic is closed.
Originally posted by Greg|H View PostI think the beauty rings make a world of difference, looking great manOriginally posted by SheaMoose View PostBeauty rings look beautiful.Originally posted by 99sil-teg View PostMan this looks so goodOriginally posted by aLaFleur View PostYep, that's all it needed man. Looks gorgeous!
Thanks guys!
So the gas leak is sorted out (I think). Taking it out to lunch in a little bit, so i'll see.
Agree, carbs are dumb. Sure, they work ok when tuned properly, but how many carbs are? EFI for the win!Originally posted by Keith602 View PostI am seriously starting to **** carburetors
Funny, The last time I was at the local Burger King hot rod meet, I was sitting in my truck about to leave and this dude in a '68 Mustang sat there (holding like 1.5k rpms with foot) for at least two minutes waiting for some heat so it wouldn't stall. (automatic
) I just bumped my key, popped it in 1st, and rolled out of the lot without touching the gas.
I've seen plenty of cars with efi run absolutely terrible.Originally posted by DER E30 View PostAgree, carbs are dumb. Sure, they work ok when tuned properly, but how many carbs are? EFI for the win!
Sensors and injectors go bad and aren't cheap.
Carbs just need to be cleaned.
Also, a properly tuned carb will have better throttle response than most efi.
Well on my 72 2002 all I have to do is pump 3 times and turn the key and then I can walk away, sounds like he needed to have his messed with.Originally posted by DER E30 View PostAgree, carbs are dumb. Sure, they work ok when tuned properly, but how many carbs are? EFI for the win!
Bottom line is old cars will have issues. I know these carbs well enough now to sort them out when something comes up. I have a back up set of su's that I can use for parts too. Yesterday I needed to swap out float chambers as the one on the car had stripped threads and was leaking. Not a big deal really. I was just venting when I said I was starting to **** the carburetors
Car might go dormant for a little bit, while I work on the trunk setup. Kind of a mess back there right now and it needs to be done properly. Its all bolted down and what not, but I want to get creative with the layout. Also, I want to run some copper hard lines. I have to decide if I want to have a spare and work with the existing setup or go no spare and have free range over the trunk. As it is now, the spare is mounted vertically and sits in a well off to the driver side. Throws off the symmetry and doesnt leave a lot of room for the tank, compressor, valves etc. Ill post pics of all that when I get into next week. Might need some advice or ideas.
Needed to check off "alley shot" for my photo locations haha. I used to be very into photography, but it was years ago and im definitely rusty.
as a person who has a daily driver without a spare i'd highly recommend keeping it. I drive 300-500+ miles a week in my M3 and i am often more than an hour away from home or friends so i keep a spare in my trunk. That plus all my camera gear leaves very little room but i feel a lot more confident when i'm on my way to a photo shoot.Originally posted by Keith602 View PostCar might go dormant for a little bit, while I work on the trunk setup. Kind of a mess back there right now and it needs to be done properly. Its all bolted down and what not, but I want to get creative with the layout. Also, I want to run some copper hard lines. I have to decide if I want to have a spare and work with the existing setup or go no spare and have free range over the trunk. As it is now, the spare is mounted vertically and sits in a well off to the driver side. Throws off the symmetry and doesnt leave a lot of room for the tank, compressor, valves etc. Ill post pics of all that when I get into next week. Might need some advice or ideas.
however, if you're never too far from home then going sans-spare leaves you with a much cleaner and more symmetrical setup in the trunk.
you really just have to weigh your options and decide how necessary it is in relation to how you use your car.
i've really enjoyed all your pics and I think you've done an excellent job especially on locations. my only advice is get lower to the ground and high up in the air to get some interesting angles....and MORE interior pics pleaseOriginally posted by Keith602 View PostNeeded to check off "alley shot" for my photo locations haha. I used to be very into photography, but it was years ago and im definitely rusty.E46 Touring Build Thread http://www.stanceworks.com/forums/sh...ad.php?t=56076
Its not my daily and I have AAA, so I might throw caution to the wind and just ditch the spare. Also I usually dont drive it more than an hour away from the house.Originally posted by austinscottphotography View Post
however, if you're never too far from home then going sans-spare leaves you with a much cleaner and more symmetrical setup in the trunk. you really just have to weigh your options and decide how necessary it is in relation to how you use your car.
i feel like you need to own this
I have totally had my eye on that model amazon! I just wish it was bigger. There are a couple on ebay and its only $40 but its tiny.
So as far as the photography, im still experimenting with settings, angles, editing, etc. I dont have a great kit, so I have to make do. I just need to keep getting out there and taking tons of shots. Also, it would be fun to shoot some other cars. I should spend more time at the location too. Usually I just take a few quick shots and bounce. Here is an attempt at an elevated perspective. Just didnt really like how it turned out.
trust me, i've done photography most of my life and it has nothing to do with equipment. i've seen people with the most expensive equipment you can buy take horrible pics and i've seen some amazing stuff done with camera phones. It's all about the person using the camera.Originally posted by Keith602 View PostSo as far as the photography, im still experimenting with settings, angles, editing, etc. I dont have a great kit, so I have to make do. I just need to keep getting out there and taking tons of shots. Also, it would be fun to shoot some other cars. I should spend more time at the location too. Usually I just take a few quick shots and bounce. Here is an attempt at an elevated perspective. Just didnt really like how it turned out.
you've taken a lot of great pics so far and I'd follow this thread just for the pics if i wasn't also an Amazon owner.
however, when i shoot cars on location i spend hours and hours either shooting my car as the stand in model or the actual car just to make sure i get the perfect shot. The more time you spend in a location the more comfortable and familiar you get with it. Shots and angles become more apparent the longer you are there.
Keep up the great work and I like the new shot.E46 Touring Build Thread http://www.stanceworks.com/forums/sh...ad.php?t=56076
