Originally posted by Sjefke
View Post
1966 Volvo 122
This topic is closed.
Im going to try that actually! Ive always thought the same thing.Originally posted by Iamtheonlyreal1 View PostThat is absolutely stunning, but I wonder if you have tried one thing that annoyed me during my build.. Your all black car with all the trim work looks awesome, and I know this is a oem design feature of the car, but the trim work around the quarter glasses really never made any sense on these cars and interrupts the image flow.. The door frame has no trim work at all, and with the stainless drip rail, it really makes the quarter glass trim conflict with the door frame section. Have you considered blacking it out? You could tape it of temporarily with some black electrical tape, and then stand off in the distance to view and take pics, just to see if it looks better overall?
Not trying to knock anything at all, because your car is a fine example of an Amazon, but that makes it stick out even more.. LOL
Okay so question time...
Im looking to roll these beastly, old Volvo fenders. I have no idea why they are so overbuilt. So im not sure what methods will work. Wonder if anyone has used the Eastwood tool on anything this thick before. Could maybe cut sections and roll them in little bits at a time. I do have a heat gun. Want to try to do this myself if possible.
Also, Is there any way to add a couple of degrees of camber to a solid rear axle (without using the torch method)? Shims, washers?
Thanks in advance
In the Netherlands on the forum I saw a guy widening his fenders. I have the pictures for you.
Ok so that guy definitely used the eastwood or similar fender roller. Any better pictures of the results or mention how difficult it was? Ive asked around a little and most people say it wouldnt work on these.Originally posted by Sjefke View PostIn the Netherlands on the forum I saw a guy widening his fenders. I have the pictures for you.
Also, does anyone have any info on adding a couple degrees of camber to a solid rear axle setup?
Originally posted by Keith602 View PostOk so that guy definitely used the eastwood or similar fender roller. Any better pictures of the results or mention how difficult it was? Ive asked around a little and most people say it wouldnt work on these.
This is the site, on the bottom of page 34 there are better pictures than i could upload here via my phone. He mentioned that it (I don't think you speak Dutch!?!?) was pretty easy. It took a minute to get the hang of. In the front he really widened the fender. In the rear he just rolled the edge in.
Someone warned that if you have repaired/welded on fenders you run the risk of it cracking...
No more result pics... That I can find.
Hope this helps
PS. Don't know anything about the camber...
