Project CQ
  • #61
    IG: awscarguy
    '90 Jetta - TSI swapping
    '13.5 Jetta GLI - new daily toy
    Haus of Dub
    • #62
      Dang this is coming along nicely!
      R.I.P P.WALKER 2013/11/30
      • #63
        Thanks man!
        IG: awscarguy
        Haus of Dub
        • #64
          IG: awscarguy
          Haus of Dub
          • #65
            swapped my front coils from the v8...the rear will be next
            so far
            AEB block
            AEB pistons w/new rings
            HoD H beam forged rods w/arp bolts
            New main bolts
            New main seals
            New orings and gaskets
            Reman AEB alternator
            AEB head
            HoD Hi Compression head gasket
            New Conti TB kit
            AWP Intake manifold
            AEB Exhaust manifold
            B6 A4 k03s
            2.5" vband downpipe
            14point7.com wideband
            AEB ECU and Harness <- no tune yet
            4 wire coil pack conversion.
            14lb A4 flywheel and stage 2 clutch
            2.5" intercooler and pipes
            Honda b18 aluminum radiator
            Perma-cool 2300cfm fan
            034 B3 silicone coolant hoses
            034 engine mounts
            034 trans mounts
            lots of little tricks...
            IG: awscarguy
            Haus of Dub
            • #66
              I guess I really should get some goof-off to unstick that insulation on the bumper
              IG: awscarguy
              Haus of Dub
              • #67
                on to the vac lines and little bit of wiring left....almost
                IG: awscarguy
                Haus of Dub
                • #68
                  What wheels are you going to run?
                  • #69
                    Probably round ones!
                    • #70
                      haha, the stock wheels for now. 4x108 makes it a little tougher for wheels. not the typical vw/audi 5x112/5x100/4x100.
                      quick 60sec 3d scan. garage computer cant handle rendering faster that 2 fps
                      IG: awscarguy
                      Haus of Dub
                      • #71
                        IG: awscarguy
                        Haus of Dub
                        • #72
                          IG: awscarguy
                          Haus of Dub
                          • #73
                            #3 coil pack was dead brand new....swapped out a spare. runs much much smoother now.
                            sits at 202* F at idle 850rpm.
                            drops down to 199* F at 2300 rpm
                            Hits 207* F while holding rpm and bouncing the revs for extended periods then cools back down to 202* F
                            IG: awscarguy
                            Haus of Dub
                            • #74
                              had a bad throttle body days before SoWo, new used came in on Tuesday and the battery was totally dead. First fire since. It was late so I couldn't be too loud. I try to be a nice neighbor.....
                              IG: awscarguy
                              Haus of Dub
                              • #75
                                IG: awscarguy
                                Haus of Dub
