Project CQ
  • #16
    Damn... is it turning over?
    R.I.P P.WALKER 2013/11/30
    • #17
      found the problem ... ....
      IG: awscarguy
      '90 Jetta - TSI swapping
      '13.5 Jetta GLI - new daily toy
      Haus of Dub
      • #18
        what was it?
        • #19
          what was it?
          there was a link in the that last post....
          http://distilleryvesper8-8.ak.instag...1f970a_101.mp4
          IG: awscarguy
          Haus of Dub
          • #20
            ordered a 20vt mls head gasket and head bolts. i can pick them up friday. I have a disassembled i5 20v head from my v8 coupe and have access to a complete stock longblock
            looks like this may be a no go for Euro Hanger...but who knows
            ill have the head pulled by tonight....too bad the previous owner didn't time the motor correctly...but if he i did...he would have converted it to an s2 by now....
            IG: awscarguy
            Haus of Dub
            • #21
              Well that there is the problem.
              its cool, picked up a stock long block for $50
              IG: awscarguy
              Haus of Dub
              • #22
                i would like to see it run stock before i do anything drastic
                • #23
                  the locals are trying to get me to 1.8t this....
                  i want to keep an inline five...but i am open to ideas
                  163hp stock - I have a 170k mi unopened long block that hasn't run in 2-3yrs
                  180hp stock - i would love to use a new vw 2.5 20v i5 motor, but it was it mounting challenges plus new harness/ecu....
                  170-190hp? stock - if i use an older eurovan 2,5 10v block..its like 8:1 with a 20v head and thus would need to get decked a bit to bring up the compression.
                  150hp stock - i have a 2001 a4 1.8t bottom end that needs honed and pistons replaced. i have a large port aeb head that was given to me yesterday that was on my old jetta(like 4-5 cars ago)...but would need a a4/passat engine harness...have a stock ecu from my old a4
                  big boost can/will be obtained on all setups above
                  IG: awscarguy
                  Haus of Dub
                  • #24
                    plans are to swap in a stock motor and swap the v8cq coilovers onto this one so i can just go out an cruise it.
                    IG: awscarguy
                    Haus of Dub
                    • #25
                      yay time to swap a motor!
                      IG: awscarguy
                      Haus of Dub
                      • #26
                        no work today....so ill work today
                        been lazy...also every chance to pickup the engine fell through. so i rented a truck and did what i had to do.
                        also snagged an early coupe "bag-o-snakes" header
                        IG: awscarguy
                        Haus of Dub
                        • #27
                          v-banded
                          about ready to swap in
                          IG: awscarguy
                          Haus of Dub
                          • #28
                            spent some time in the garage today.
                            034 engine mounts
                            034 front snub mount
                            034 silicon coolant hoses
                            034 silicon breather hoses
                            new reman starter
                            new reman alternator
                            new reman crank dampener
                            new crank timing gear
                            new timing belt, water pump, bearing
                            fresh synthetic 10-30, new filter
                            IG: awscarguy
                            Haus of Dub
                            • #29
                              Glad to see this thing is still alive and going (well about to be anyway).
                              Did you swap the coils over yet? Does it crank/turn over?
                              • #30
                                battery crapped out soon as i went to start it. ha
                                coils are not on just yet, want to see it run drive before i did that. also had a few offers to buy it sight unseen...(could then finish the v8 coupe) so not sure what my plans are.kinda just going with the flow of things
                                IG: awscarguy
                                Haus of Dub
