Cool i guess....
'70 Volksrod
Don't try to talk me into it or anything lolOriginally posted by ChuckNDicks View PostA lot of people that build them do so because it's a really low budget way to get into hot rodding. A lot of people also bitch out on doing chops and just take off the fenders and throw on a beam extension and call it a volksrod.
You should build one. It is a real good time, and if you don't do huge rear tires or a tunnel raise you can build one pretty quickly. here are also a few different ways to do the roof chops depending on how low you wan the roof to be. Some of them are simple enough to pull off in a couple hours.
Super mediocre update:
Picked up hardware to finish mounting the seats and lap belts today. Other than that, I have some customer cars and motorcycles to work on before I can get back on this thing.
I believe so. I haven't even looked at it much more than I know its a cx500. It doesn't crank or run at the moment. So I'll be going through it in a couple minutes and see if I can't make magic happen on the customers super small budget.Originally posted by mfergel View PostCX500 Deluxe, correct? I used to have a CX500 Deluxe - my first bike.
Got rear tires finally, and pushed it out of the garage. I need to raise the rear up a notch (about 2.5"), the floor pans scraped coming out of the garage, and its not a very steep grade at all....
Front tires and all the brake lines and fuel lines, along with a new throw out bearing should be on the way next week. After I get some customer cars out of the way I will hopefully be able to get the motor going in the next two weeks and take it for a spin around the block.
Also will be making a small push bar for the front end that will also double as a headlight mount, that'll get the headlights down low and out front where they should be.
